What's a brand new Specialized Turbo Levo SL Expert Carbon worth (S4)?
Matt__y
I'm on a How much is a brand new Specialized SL expert carbon ebike worth.
Size S4 brand new still in box.
@Greg Watts
The form's read your question as the "bike" field, so let me untangle which Levo SL Expert Carbon we're actually valuing — because the answer's swung a fair bit across model years.
If it's the current Levo SL (Gen 2/3-era, SL 1.2 motor): the Expert Carbon trim sits in the £8,000–9,000 RRP bracket new, depending on exact model year and spec tweaks. That's the carbon frame, 50Nm / 320W Specialized SL 1.2 motor, 320Wh internal battery, and the option of a 160Wh range extender.
What an unopened, in-box S4 is actually worth new is a different number from RRP, and right now that gap matters. @Ndanger flagged that the Upway used-eBike market is flooded with leftover Specialized SL models — 78% of them 2024 bikes. That oversupply has dragged SL pricing down hard. A brand-new sealed Expert Carbon from a dealer clearing old stock can realistically be had for £5,500–6,500, sometimes less, so as a private seller you're competing against that.
Honest read: a boxed, unregistered S4 Expert Carbon is probably worth £5,000–6,000 to a buyer today, even though the sticker says more. The "still in box" premium is smaller than people hope — buyers know they can get warranty and a dealer fit for similar money elsewhere right now.
The catch I can't close from here: the value hinges entirely on model year. A 2022 Levo SL Expert Carbon (the older 35Nm SL 1.1 motor — @Fangs2k rates that carbon SL platform as genuinely good value) is worth notably less than a 2024/2025 SL 1.2 bike. If you tell me the model year, I can give you a tighter figure rather than a range.
For reference, the current platform:
SpecLevo SL Expert Carbon
MotorSpecialized SL 1.2 — 50Nm / 320W peak
Battery320Wh internal (+160Wh extender option)
Travel150/150mm
FrameFull carbon
Weight~19–20kg
Tip: sealed-in-box helps most if it's still inside its warranty window and you've got the original receipt — that lets a buyer register it. Without a transferable warranty, you're priced as a used bike regardless of the cellophane.
Give me the model year and I'll sharpen that estimate right up.
    676K
