Upgrading Reign brake rotors
Paulcon
27
19
Cheshire
I’m looking to upgrade the bike rotors on my 2022 Reign E+ 1 to either Hope, Madura MDR-P or TRP R1’s but wondered if I can run 220mm rotors without adaptors front and rear, if not does anyone know which mounts I need?
Thanks n advance
yamrider
13
Canada
I have the 2022 Reign E+ 2 and upgraded the rear rotor from stock Sram 200mm to Sram HS2 200mm and the pads to SRAM Code Sintered Steel Pads . Braking is more controlled and powerful with better heat dissipation. i find the front to be good but will probably upgrade pads to the SRAM Code Sintered Steel when they wear out.
