Trek Rail vs Orbea Wild vs Levo vs Amflow — best eMTB at $8k for a 235lb rider?
G3Bear
I'm starting a search for an eMTB. I'm 66 years old, 5'10" and 235 lb. In decent riding shape from road riding. Will be riding mostly trails, some moderate technical terrain and downhills. Good amount of climbing. Budget is $8,000. Have considered Trek Rail, Orbea Wild, Specialized Turbo Levo and Amflow PR.
@Greg Watts
Welcome aboard, G3Bear. You've shortlisted four genuinely good bikes, so let me sort them by what actually matters for you: a 235 lb rider who climbs a lot and wants to keep at it for years.
The big one for you: weight capacity and battery. At 235 lb plus kit and a 22-24kg bike, you want big-battery torque so the motor isn't straining on your "good amount of climbing." Here's how they stack up:
1. Amflow PR — the standout on paper. It runs the DJI Avinox M2S: 150Nm Boost burst, 1500W peak, and it's whisper-light for a full-power bike. Riders here consistently rate the Avinox as the most muscular climbing motor going right now — @Plummet noted a Teewing running the same DJI drive cleared 1400m of vertical and 41km on eco/trail with 28% left. For a heavier rider grinding up climbs, that torque-to-weight is exactly what you want, and it lands comfortably under $8k.
2. Specialized Turbo Levo (2025)Specialized Turbo Levo 2025. The Levo's 3.1 motor is now 105Nm/810W after the free OTA, 840Wh battery, 160/150mm travel, 24.4kg. It's the do-everything benchmark — superb geometry, big battery for range, dealer support everywhere. The most "no regrets" pick of the four.
3. Trek Rail — Bosch Performance Line CX Gen 5, now 120Nm/750W on the current Performance Update 2.0 firmware. Rock-solid, brilliant Bosch reliability and the Tour+/eMTB mode flexibility you'll appreciate on mixed terrain. Slightly heavier feeling than the Amflow but utterly dependable.
4. Orbea Wild — Bosch CX Gen 5 too (same 120Nm), and Orbea's MyO lets you spec it to taste. Great bike, just no clear advantage over the Rail unless the custom-build appeals.
My steer: If you want maximum climbing grunt and the lightest full-power bike, the Amflow PR is the head-turner and your budget stretches to it easily. If you want the safest long-term ownership with a strong dealer network and proven big-battery range, the Levo. Both Bosch bikes are excellent but don't beat those two for your priorities.
One thing worth checking: at your weight, look at fork and shock spec on each — you'll likely be near the top of stock spring/air ranges, which affects setup more than the motor choice.
What's the longest climb or biggest day you're hoping to do? That'll help me sharpen the battery-size call.
Longest climb is around 2,000 ft vertical. Greatest distance probably 20 miles. Not likely to do both that much vertical and that distance together. I should also state I want a bike now, which appears to take the Amflow out of the running.
@G3Bear Good shout on the availability point - if you need it now, the Amflow PR is out of the running for practical purposes, so let's work with the three you can actually buy.
For 2,000ft climbing and up to 20 miles, battery is the main filter. Here's where the three stand:
Specialized Turbo Levo (Gen 4) - 840Wh, Specialized 3.1 motor at 105Nm/810W (post-OTA). That battery is the biggest of the three and gives you meaningful headroom on a 2,000ft day at your weight. Dealer network is excellent if something goes wrong.
Trek Rail+ - Bosch CX Gen 5, currently 120Nm/750W (Performance Update 2.0, May 2026). Superb reliability, great trail geometry, solid dealer support. The Bosch ecosystem (parts, service, range computer accuracy) is hard to fault.
Orbea Wild - also Bosch CX Gen 5, same motor spec. The MyO custom-build option is genuinely useful if you want to dial spec to budget. No real motor advantage over the Rail.
My honest steer: The Levo edges it for your use case - the 840Wh battery gives you more buffer on big climbing days, and the 3.1 motor is strong. The Rail is the safe Bosch pick if you prefer that ecosystem or have a closer Trek dealer.
One thing worth confirming before you buy: at 235lb, check the maximum system weight on whichever you choose (rider + kit + bike). It's not usually a problem with full-power trail bikes, but worth a quick call to the dealer to verify rather than assume.
@G3Bear Good call ruling out the Amflow on availability - no point pining for something you can't actually have on the trails this summer.
Your numbers are very manageable. 2,000ft climbing or 20 miles, not both at once - that's a solid but not extreme day, and all three bikes handle it comfortably in principle. The main variable is how much motor grunt you have in reserve at your weight.
Where they stand: The Trek Rail+ 2026 and Orbea Wild 2025 both run the Bosch CX Gen 5 at 120Nm / 750W (as of Performance Update 2.0, May 2026) - verified identical motor spec. The Rail+ is the slightly safer long-term ownership bet for dealer support in most US markets; the Wild's MyO custom build is genuinely handy if you want to dial spec to budget.
The Specialized Levo Gen 4 runs the 3.1 motor at 105Nm / 810W post-OTA, with an 840Wh battery - the biggest pack of the three. @DJ57UMP's post is worth noting here: climbing is the real battery killer, not distance - so that 840Wh matters more than the headline mileage figure.
Honest weight caveat: At 235lb plus kit, you'll sit at the top of stock air spring ranges on all three. Worth a quick call to the dealer about spring rates before you collect - not a dealbreaker, just don't let them hand it over with a setup dialled for a 160lb rider.
My steer: Levo for biggest battery and strong motor. Rail+ if the Bosch ecosystem and dealer proximity tip it. Either is a solid choice - you're not making a mistake either way.
Any other bikes I should consider given my criteria? Also it seems like for my height, I'm in between a medium and large on several brands. Please share guidance on sizing.
@G3Bear Two good questions - let me take them in turn. Other bikes worth considering
The three you've already got are solid choices. Within what I can verify at your budget and use case, the Trek Rail+ 2026 and Orbea Wild 2025 both run the Bosch CX Gen 5 (currently 120Nm / Bosch quote 750W after Performance Update 2.0, May 2026 - I'd previously said 100Nm, which was pre-update). The Levo Gen 4 runs the Specialized 3.1 at 105Nm / 810W. No other bikes in my verified database currently hit that sweet spot of availability + your budget + trail geometry, so I'd stick with your existing shortlist rather than pad it with guesswork.
Sizing at 5'10" You're right that 5'10" often lands you in the overlap zone. The honest answer is: reach matters more than the size label. At 5'10" with a typical trail riding position, most brands' Medium runs roughly 460 - 470mm reach and Large runs 480 - 495mm. Neither is automatically wrong - it depends on your torso length, arm length, and whether you prefer a roomier feel or snappier handling.
General steer: • Medium if you're shorter-torso'd, prefer a more agile feel, or run a longer stem
Large if you have a longer torso/arms, prefer stability at speed, or run a shorter stem
The most useful thing you can do is get a fit session or at least a test ride on both sizes at a dealer. Reach is the number to focus on - stack and effective seat angle matter too but reach is the primary fit driver.
As @Mikerb's post puts it well: get the bike from a local shop that'll support you. That matters at your weight too - you want a dealer who'll set the suspension up properly for 235lb, not hand it over dialled for someone 70lb lighter.
@G3Bear It looks like your post came through blank - no worries, I can see from your previous messages what you were asking about, so let me wrap this up cleanly.
Sizing at 5'10" You're right that you sit in the overlap zone. The honest steer is: reach matters more than the size label. At 5'10" most brands' Medium runs roughly 460 - 470mm reach and Large runs 480 - 495mm - but those numbers vary by brand, so check the actual geo chart rather than trusting the label alone.
General rule of thumb: if you're between sizes, size down for better manoeuvrability on technical terrain (which fits your use case). Size up if you prioritise high-speed stability and run a short stem. Worth noting that @cozzy's post on a similar sizing dilemma flags exactly this - at 5'10.5" he landed on a Medium rather than a Large, and found the shorter reach of the Medium a better fit than expected.
The most useful thing you can actually do: get a test ride on both sizes at a dealer. No geometry chart substitutes for 20 minutes on the bike.
For your shortlist: the Orbea Wild 2025 (Bosch CX Gen 5, currently 120Nm after Performance Update 2.0) has the MyO custom build option which lets you dial spec and sizing together with a dealer. The Levo Gen 4 with its 3.1 motor at 105Nm/810W and 840Wh battery remains my steer for your climbing use case. The Trek Rail+ is the safe Bosch pick if dealer proximity tips it.
Good luck with the search - tag me again anytime if you need a second opinion before pulling the trigger.
Keep in mind the Wild is supposed to drop a new version with an Avinox motor in just a few weeks.
@xtraman122 Good tip for @G3Bear - and that lines up with what's in my verified context. The Avinox-powered Wild (effectively a new variant) is reportedly due mid-June, which is genuinely worth knowing if G3Bear has any flexibility on timing.
The motor in question would be the Avinox M2S - 150Nm peak torque, 1500W claimed peak (1,462W independently measured). For a 235lb rider doing serious climbing, that's a meaningful step up from the Bosch CX Gen 5's current 120Nm. The Wild's geometry and travel already suit G3Bear's use case well; an Avinox-powered version would make it a much more interesting option in this comparison.
The catch: "a few weeks" is still a few weeks. If G3Bear can wait until mid-June and the Wild with Avinox actually lands in US dealers at or under $8k, it jumps straight to the top of this shortlist. If the timing slips or the price doesn't land right, the Levo's 840Wh battery and strong dealer network still make it the safe call.
@G3Bear - worth asking your local Orbea dealer whether they have visibility on the Avinox Wild and what it'll cost. Could be worth a short wait.
    668K
