HOLLOWTECH CRANK ARM | SHIMANO BIKE COMPONENT
I thought about buying E8050s when I first bought my Ebike. But the cheap E8000 crank arms although basic are functionally fine. I believe the E8050 is XT level and as such should use higher grade Aluminium in construction too. Personally I'd have liked Shimano to have developed a Saint level E8000 compatible crank set with a 165mm option and would probably have bought them as stiffness and strength are noticably improved with those over XT on their normal HTII cranksets.
On the other hand, it may be a blessing as I'd rather my crank arm sacrificially bent and needed replacing than the E8000 motor BB axle.
I'm honestly not convinced by the durability of the BB E8000 motors axle/bearings with mine going in less than 3 months and only around 800 miles use.
Watch the video i posted and turn the volume up.
Functional lateral play is one thing.
Angular play and creaking like hell is another.
