Teewing Turbo Force vs Orbea Wild vs Santa Cruz Vala: which to buy?
Hunter86
Hello Greg,
Should I get the Teewing Turbo Force, Orbrea wild or Santa Cruz vala
Hello Greg, Should I get the Teewing Turbo Force, Orbrea wild or Santa Cruz vala
Three very different bikes here, so the choice really comes down to what you want out of it.
Quick lay of the land:
Santa Cruz Vala - Bosch Performance Line CX Gen 5 (120Nm), 600Wh, 160/150mm mullet trail bike.
Polished, predictable, brilliant frame.
The Bosch CX is the most proven, best-supported motor of the three - worth weighing given you've mentioned Avinox warranty/service availability being patchy.
Downside: 600Wh is the smallest battery here, and the CX has a bit more unassisted drag than rivals.
From £6,899.
More travel, more power, bigger battery - this is the gravity-leaning, biggest-hitting option of the three.
The M2S is the strongest motor on paper.
From £6,199 for an entry build, which is frankly good value.
The catch is the one you already know about: Avinox service/warranty coverage can be a question mark depending on where you are in Australia.
Newer brand, so the unknown is dealer support and long-term backup rather than the bike itself.
Worth noting it's the priciest here despite the lower-spec M1 motor.
So, the honest steer:
• Want the safe, sorted, best-supported bet →
Vala.
• Want the most bike for the money and aren't scared of Avinox support →
Wild LT.
• The Teewing's a harder sell at that price unless something specific about it grabs you.
Given Australia and your worries about Avinox backup, the Vala's the one I'd nudge you toward unless you really want that extra travel and battery.
One thing I can't pin down from here is your actual riding - are you doing big descents and bike-park stuff, or mostly trail miles?
That swings it between the 170mm Wild and the 150mm Vala more than anything else.
What's the terrain like where you ride?
From £6,899.
Vala.
Wild LT.
Thanks for this info. They are all very different just because these are all different shops here in the United States getting rid of stock. The teewing and vala are closer in fork range. The wild seems like a killer deal that I can't see to find anywhere else. I also don't know if I need that much travel just going on trails and not going on crazy down hill. I the teewing seems interesting worried about warranty but the shop says he will take care of me. The vala is hit and miss on the components for the price point. I will be just starting out and it will be more all mountain or easy trails vs bombing down hill.
Thanks for this info. They are all very different just because these are all different shops here in the United States getting rid of stock. The teewing and vala are closer in fork range. The wild seems like a killer deal that I can't see to find anywhere else. I also don't know if I need that much ...
First off - apologies, I had you in Australia earlier.
You're in the US chasing shop clearance stock, which actually changes the calculus a bit since Avinox support coverage varies by region there too.
Here's the thing that simplifies this: you've just told me you're
starting out, doing all-mountain and easy trails, not bombing DH.
That alone tips the scales.
The Wild LT is built for a job you're not asking it to do. It's a 170/170mm gravity-leaning enduro bike - brilliant if you're hammering bike park, but it's a lot of bike for mellow trail miles.
Killer deal or not, you'd be buying capability you'd rarely use, and a long, slack enduro rig is more of a handful to learn on.
Lovely motor (the Avinox M2S), but it's the wrong tool for your brief.
That leaves the Teewing Turbo Force and the Santa Cruz Vala - and you're right, those two are much closer in spirit.
Both are ~160/150mm trail bikes, which is the sweet spot for what you're describing.
SpecTeewing Turbo Force ProSanta Cruz Vala
Travel (f/r)160/150mm160/150mm
FrameCarbonCarbon
The honest steer for a first bike:
Vala - the Bosch CX Gen 5 is the most proven, best-supported motor of the bunch, which matters a lot when you're new and don't want to be wrestling warranty headaches.
Downside is the smaller 600Wh battery, and you flagged the components feeling hit-and-miss for the price - worth checking the exact build the shop has.
From what I understand, Avinox's dealer-support network is still patchy in places, so I'd want that promise in writing.
For a beginner who values not being stranded by support: I'd lean
Vala , pending you eyeballing that exact spec sheet.
If the Teewing build is meaningfully better-specced and the shop's backing is genuinely solid, the bigger battery makes it tempting.
What's the actual build/components on the Vala the shop has?
That's the bit that'll settle it.
That number - 187548 - doesn't ring any bells in the context of this conversation. Are you sharing a stock number, a price, or maybe a product ID for one of the three bikes?
If it's a price in USD, that's actually useful context - at $187,548 we'd be having a very different conversation involving a custom titanium build and a personal mechanic on retainer. But I'm guessing it's something more earthly. 😄
Drop a bit more detail and I'll make sense of it - what's the 187548 referring to?
Here is the build for teewing
Frame Teewing, Turbo Force Frameset, Large, Black/Gold, 2026
Motor Avinox, M2S Motor Kit, 2026
Battery/Charger Avinox, Avinox 800W Battery
Fork Marzocchi, Bomber Z1, 29, Black, 160mm, 2026
Shock Marzocchi, Bomber Air, 185x55
Shock Hardware Fox, Shock Hardware, 8x36
Drivetrain SRAM, SRAM GX Wireless Transmission, XD
Chainring SRAM, T-Type Chainring, 36T
Front Wheel Boyd Cycling, Kanuga FF, 29, Aluminum, 15x110, Front, 2026
Rear Wheel Boyd Cycling, Kanuga FF, 29, Aluminum, 12x148, XD, 2026
Front Tire Vittoria, e-Martello, 29, Black, 2.4
Rear Tire Vittoria, e-Mazza, 29, Black, 2.4
Brakes Magura, MT7 Pro
Front Rotor Magura, MDR-C, 203mm
Rear Rotor Magura, MDR-C, 203mm
Brake Adapter Magura, QM 44, 23mm Brake Mounting Adapter
Seatpost OneUp, V3 Dropper, 180, 31.6
Lever OneUp, V3 Dropper Remote, Black
Stem RaceFace, Turbine Stem, Black, 35mm clamp, 40mm, 2025
Handlebar RaceFace, Turbine Handlebar, 35x20x780, Black, Aluminum, 35mm, 780mm, 20mm
Grip RaceFace, Half Nelson Grip, Black
Cranks Avinox, DJI Avinox Crank, 155mm, Black
Pedal RaceFace, Chester Pedal, Large, Black, Composite
Electronics SRAM, AXS Motor Cable, Higo, 2pin, DJI, 780mm
Saddle WTB, Koda Medium, 255 x 145mm, Black, Steel
Tire Sealant Drip e-Bikes, Tubeless Sealant, 300ml
Vs the build for the vala
Fork
RockShox Zeb Base, 160mm
Shock
FOX Float X Performance, 205x60
Rear Derailleur
SRAM 70 Eagle T-Type, 12spd
Shifter
SRAM 90 Eagle T-Type, Single Click, 12spd
Crankset
E13 Helix eSpec, 160mm
Cassette
SRAM XS 1270 Eagle T-Type, 10-52t
Chain
SRAM 70 Eagle T-Type, Flattop, 12spd
Bottom Bracket
N/A
Stem
OneUp Enduro Stem, 42mm -or- e13 TRS Base Stem, 40mm
Headset
Cane Creek 10 IS Integrated Headset
Saddle
SDG Bel-Air V3 Max
Front Rim
Reserve 30|HD AL
Front Hub
SRAM MTH 716, 15x110, 6-Bolt, 32h
Front Tire
Maxxis Assegai 29"x2.5", 3C MaxxGrip, EXO+
Rear Rim
Reserve 30|HD AL
Rear Hub
SRAM MTH 746, 12x148, HG, 6-Bolt, 32h
Rear Tire
Maxxis Minion DHRII 27.5x2.5, 3C MaxxTerra DoubleDown
Headset
Integrated (IS41/52)
Seat Post Diameter
31.6mm
Seat Clamp Diameter
36.4mm
Rear Brake Mount
200mm PM
Max Tire Clearance
2.5"
Max Chainring Size
36t
Water Bottle Mounts
Shock Length
205mm
Shock Stroke
60mm
Shock Mounting Hardware Upper
Trunnion
Shock Mounting Hardware Lower
8x30
Fork Offset
44mm
Here is the build for teewing Frame Teewing, Turbo Force Frameset, Large, Black/Gold, 2026 Motor Avinox, M2S Motor Kit, 2026 Battery/Charger Avinox, Avinox 800W Battery Fork Marzocchi, Bomber Z1, 29, Black, 160mm, 2026 Shock Marzocchi, Bomber Air, 185x55 Shock Hardware Fox, Shock Hardware, 8x36 Driv...
This is a big deal - the build sheet changes the whole picture.
The most important thing first:
Avinox M2S motor and the 800Wh battery - not the M1 my records had for the "Turbo Force Pro." So scratch what I said about it being a weaker M1 motor; this thing has the proper full-fat drive unit.
That genuinely improves the case for it.
Let me lay the two side by side on what actually matters:
BrakesMagura MT7 Pro, 203/203(shop to confirm)
WheelsBoyd Kanuga FF alloyReserve 30 HD AL
TyresVittoria e-Martello / e-MazzaMaxxis Assegai / Minion DHRII
A few honest flags:
Still the stronger motor of the two, with the bigger battery.
That's a real advantage.
The Teewing build is, frankly, the more generous spec sheet. GX AXS wireless Transmission, Magura MT7 Pro brakes (excellent stoppers), a OneUp V3 dropper - that's a properly sorted kit.
The Vala's mechanical SRAM 70 and the "hit-and-miss components" you flagged earlier line up with that.
• On the Boyd Kanuga FF wheels - I couldn't pin down verified weight or internal-width figures for those, so I won't guess.
They're a legit US brand though, not a no-name rim.
• The two things that should still give you pause on the Teewing are exactly the ones you already named: warranty/support (get the shop's promise
in writing - "he'll take care of me" is worth precisely what it's printed on) and Avinox dealer backup in your region.
So where does that leave you?
The earlier "lean Vala" steer was partly built on the Teewing being a weaker-motored bike.
It isn't - this build is genuinely the better-equipped, bigger-battery, stronger-motor option.
The Bosch CX on the Vala remains the more proven, easier-to-service motor, which still counts for a lot when you're new.
For your brief - all-mountain, easy trails, not bombing DH - both are right-sized at 160/150mm.
If the Teewing shop's support is real and in writing, that build is hard to argue against on value.
If you want the safest service net and don't mind the smaller battery and plainer kit, the Vala.
What did the shop actually say on warranty - length, and who honours it?
    676K
