Three very different bikes here, so the choice really comes down to what you want out of it.Hello Greg, Should I get the Teewing Turbo Force, Orbrea wild or Santa Cruz vala
Thanks for this info. They are all very different just because these are all different shops here in the United States getting rid of stock. The teewing and vala are closer in fork range. The wild seems like a killer deal that I can't see to find anywhere else. I also don't know if I need that much travel just going on trails and not going on crazy down hill. I the teewing seems interesting worried about warranty but the shop says he will take care of me. The vala is hit and miss on the components for the price point. I will be just starting out and it will be more all mountain or easy trails vs bombing down hill.Three very different bikes here, so the choice really comes down to what you want out of it.
Quick lay of the land:
Santa Cruz Vala - Bosch Performance Line CX Gen 5 (120Nm), 600Wh, 160/150mm mullet trail bike.
Polished, predictable, brilliant frame.
The Bosch CX is the most proven, best-supported motor of the three - worth weighing given you've mentioned Avinox warranty/service availability being patchy.
Downside: 600Wh is the smallest battery here, and the CX has a bit more unassisted drag than rivals.
From £6,899.
More travel, more power, bigger battery - this is the gravity-leaning, biggest-hitting option of the three.
The M2S is the strongest motor on paper.
From £6,199 for an entry build, which is frankly good value.
The catch is the one you already know about: Avinox service/warranty coverage can be a question mark depending on where you are in Australia.
Newer brand, so the unknown is dealer support and long-term backup rather than the bike itself.
Worth noting it's the priciest here despite the lower-spec M1 motor.
So, the honest steer:
• Want the safe, sorted, best-supported bet →
Vala.
• Want the most bike for the money and aren't scared of Avinox support →
Wild LT.
• The Teewing's a harder sell at that price unless something specific about it grabs you.
Given Australia and your worries about Avinox backup, the Vala's the one I'd nudge you toward unless you really want that extra travel and battery.
One thing I can't pin down from here is your actual riding - are you doing big descents and bike-park stuff, or mostly trail miles?
That swings it between the 170mm Wild and the 150mm Vala more than anything else.
What's the terrain like where you ride?
First off - apologies, I had you in Australia earlier.Thanks for this info. They are all very different just because these are all different shops here in the United States getting rid of stock. The teewing and vala are closer in fork range. The wild seems like a killer deal that I can't see to find anywhere else. I also don't know if I need that much ...
| Spec | Teewing Turbo Force Pro | Santa Cruz Vala |
| Travel (f/r) | 160/150mm | 160/150mm |
| Frame | Carbon | Carbon |
That number - 187548 - doesn't ring any bells in the context of this conversation. Are you sharing a stock number, a price, or maybe a product ID for one of the three bikes?187548
This is a big deal - the build sheet changes the whole picture.Here is the build for teewing Frame Teewing, Turbo Force Frameset, Large, Black/Gold, 2026 Motor Avinox, M2S Motor Kit, 2026 Battery/Charger Avinox, Avinox 800W Battery Fork Marzocchi, Bomber Z1, 29, Black, 160mm, 2026 Shock Marzocchi, Bomber Air, 185x55 Shock Hardware Fox, Shock Hardware, 8x36 Driv...
| Brakes | Magura MT7 Pro, 203/203 | (shop to confirm) |
| Wheels | Boyd Kanuga FF alloy | Reserve 30 HD AL |
| Tyres | Vittoria e-Martello / e-Mazza | Maxxis Assegai / Minion DHRII |
