Speedo correction
outerlimits
E*POWAH BOSS
1,241
1,574
So my Speedo on the app reads about 2kmh higher than my Garmin.
Wheel dia is 2250
Which way should I adjust it to bring it in line?
ccrdave
1,418
1,120
uk
according to sheldon brown
27.5 fitted with a 3inch tyre = 2313.47mm circumference
27.5 fitted with a 2.75inch tyre = 2273.57m circumference
ccrdave
1,418
1,120
uk
me too, I set mine at 2275 problem I found is difference in size between 2.8 tyres so for me a good guess is good enough
outerlimits
E*POWAH BOSS
1,241
1,574
Going by the above I worked out it should be 2281mm
Will be a case of checking and adjusting to suit
caterhamnut
128
85
South West
ah, so this would explain why my Strava feed that comes from the mission control reads, say 19miles, where as the Strava data that comes from my phone all will read, for example, 24 miles, for the same ride/
Doomanic
🛠️Wrecker🛠️
8,486
9,965
My Strava reads lower than my Intuvia but it reads higher than my mate's Garmin.
outerlimits
E*POWAH BOSS
1,241
1,574
I have tried lots of different settings of late and nothing seems to make a difference to speed or distance traveld.
kcarbon
241
140
australia
I will have to adjust mine , as I went from the 27.5 x 2.8" butcher to 27.5 x 3.0" same as 2017 fatty's use. main reason I changed is, I had a 2017 fatty levo HT. I noticed that rolled a lot better. I also road a 2017 expert that had the 27.5 x 3.0. & I could notice it rolled like my old fatty HT levo. only thing I notice with the 27.5 x 3.0" set at 12psi F 15psi R ( tubeless ) is it I'm on a paved path and I ride off path over grass, steering feels strange ( very hard to explain ) but I'm used to it. I go around corners on paved surface at up to 60kph ( down hill ) via my Garmin 520 and bike handles well (tight corners )
outerlimits
E*POWAH BOSS
1,241
1,574
Yeah the rolling diameter of the 3.0 is greater so it will roll slightly better. As for steering strange in grass, it may be due to the wide tyres giving more resistance.
I have had my Levo up to 89kmh and it felt solid and safe. My old enduro bike with 2.3 tyres felt shakey at 70kmh
Rob Rides EMTB
Administrator
Staff member
6,165
13,308
Surrey, UK
89KMh :eek:
kcarbon
241
140
australia
Thank's Rob, I'll have to check speed we hit down hill tomorrow as it's a fast run. might see if I can get mission control to check speed as have to keep eye out for cars on this section. what do you use to check speed?
outerlimits
E*POWAH BOSS
1,241
1,574
I use Cops to check my speed.... On the Levo they got no chance LOL
524K
