Levo Gen 2 Speed problem Specialzed vs garmin edge 1030
henk vogel
Nederland
My Browse motor was from 2016 and i manipulated it by wheelmm.
It works correct until i get a new brose motor 2020.
I manipulated it by Light blue to a wheelcircle of 800mm, speed to max >40km.
Now my gps edge 1030 gives a wrong speed, related to the 800mm wheelcircle.
I tryed Blevo to correction the signal (in settings) was (don't use motor gps signal.)
But this dos'nt work.
Can you give me an solution please?
(By the way, all other functions are ok from Blevo)
Energy, batterie, cadance etc.
There is also connection with the Browse motor.
Henk Vogel
Netherlands
salko
1,241
837
SLO
Brose motor does not have GPS signal. On Edge check the wheel circumference setting under speed sensor from bike, to display correct speed you must set actual wheel circumference there.
henk vogel
Nederland
Thnx Salko
I have the correct Wheel circumference, 2250mm for my 3” tires.
the gps should get thespeed information from satellites. (Excuses my poor English)
If i go back (in Brose) to an Lower reference of 800 mm. Imidiality i get an wrong speed.
question is, it Will Be fine to have the real speed, Max speed and distance
Henk
henk vogel
Nederland
For your information. If the contact between Brose and Edge is lost, than are speed en distance correct, but i mis power, cadense and battery info.
