Speed Sensor replacement Cable Repair Giant Yamaha SyncDrive Pro
AgusReezal
Madrid, Spain
Hola, are you tired of buying and replacing the speed sensor or the cable of your ebike? In my case it was the second time it got broken and I decided to replace it for something much cheaper. A magnetic switch (less than 10 $) that works exactly the same as the original one which is very expensive. In this video you can see the procedure. The references of the original replacements: 245MYAMH-02V (40 $ for a cable 700 mm with a magnetic switch in one end! Crazy!
LG650 X94-81670-20 (20 $) for a piece of cable 650 mm long
Hope this helps !!!!!!
Reed switch en Aliexpress 2 eur/$ 1.73£ 15% de DESCUENTO|Interruptor De Lengüeta De 5-10 Piezas, De 3 Pines Interruptor Magnético, 2,5x14mm, Conversión Normalmente Abierta, Normalmente Cerrada, 2,5x14mm, Sin Conversión Nc Para Sensores - Interruptores - AliExpress
Reed switch amazon:
542K
