Shimano BT-E8010 bottom battery connector
miikasd
My battery connector (the one which attaches to a bike) has worn out on Shimano BT-E8010. Where can I get a new one?
That worn "bottom" connector is almost certainly the frame-mounted contact block rather than anything on the battery itself - Shimano calls it the BM-E8010 mount/connector unit, and it's the bit that takes the abuse every time the pack goes in and out.
It's available as a genuine spare, not just a warranty-only part. ebike24.com stocks Shimano STEPS battery spares including the BM-E8010 holder/lock components, and Tradeinn/Bikeinn list a dedicated "battery connector support" listing for the BM-E8010 too - worth checking both for stock and price before assuming it's unobtainable.
Worth knowing before you order: this exact issue - connectors cracking and Shimano being slow or unhelpful on replacement - has come up here before. @Cyclopath1000's post (2021, so a while back) flagged the same cracking connector and struggled to get a replacement part through normal channels, eventually keeping a spare battery as insurance. If genuine stock is thin when you look, @fuikatasio's post mentions the connector itself can be sourced cheaply from AliExpress and swapped in if you're comfortable soldering - not official, but a workable fallback others here have used.
One practical check: confirm which end has actually worn - the battery-side pins or the frame-side mount - before ordering, since Shimano sells them as separate parts and you don't want the wrong half turning up.
No, it really is the connector on the battery itself what has worn off, not the frame mounted contact block..
Fair enough, that flips it - thanks for the clarification, @miikasd. If it's the battery-side connector itself that's chewed up, that's the bit shops and Shimano tend to be stingiest about, because it's normally treated as internal to the sealed pack rather than a stocked spare. Worth knowing: @cream's found that no manufacturer will sell individual internal battery parts, meaning the practical route is usually a whole donor battery with a good connector rather than the part on its own.
Before you go down that road though, two things worth checking first:
• Get eyes on exactly what's damaged. @Wookie_73 described the same fault - the internal tabs which push against the frame's spade connector had been damaged, which then cooked the connector further with heat. If yours looks like that, it's a wear/heat cascade, not a one-off snap.
• Check the actual electrical symptom, not just cosmetic wear. If you're getting power fluctuations or shutdowns alongside the worn look, contact resistance rising from a degraded connector is exactly what @cream flagged as the mechanism.
Realistically, for the battery-side connector specifically, your options are: a genuine warranty claim through a Shimano dealer (worth ringing round, since this is treated as an internal fault not user-serviceable), or sourcing a second-hand BT-E8010 pack with a healthy connector as a donor. I don't have a confirmed standalone retail listing for just that internal connector - if I find one I'll flag it, but I'd rather say that than send you chasing a part that doesn't exist as a separate SKU.
    Join 43,289
