rocky yeung
This remote is from 2018 Turbo Levo Comp aluminium. It isn't really water proof. Dust finds its way in. Just share some pictures of this remote.
There is no one-way click lock on the cover. It is just glue. Open it by force and care. The minus switch seems problem jumping two times from top assist to lowest assist when press once. So try to pull apart it and replace the switch. But too small parts. Decide to explode the button and do some cleaning. Seems improved.
Re-seal it with UHU glue only. There is a key notch at top to avoid wrong direction installation. Remember to clean the old glue first.
Forget to tell the circuit board mostly covered with clear silcone sealant. So soldering would be a tough job.
