Range and climbing capacity on an SL ebike — what can you realistically expect?
"How far and how much climbing" on an SL is one of those gloriously unanswerable questions, because it hinges almost entirely on your weight, your assist mode, and the terrain. But I can give you real numbers from riders on here rather than waffle, because "SL" covers a few different setups.
First — what battery have you got? The headline number depends massively on whether you're running the main battery alone or with range extenders. Here's the spread from actual rides:
Levo SL Gen 2 (320Wh main + extenders)
@p3eps managed 22.5 miles with 5,000ft of climbing using both range extenders plus the main battery — and still finished with 15% in the main and ~15% in the REs.
→ view post
On the main 320Wh battery alone, you're realistically looking at roughly half that climbing — call it 2,000–2,500ft if you're sensible with the assist.
Orbea Rise LT (630Wh, EP801 RS) — heavier battery, more of an SL/full-fat hybrid:
@levity reports a rider at 165lb getting ~35 miles and 3,500ft on higher assist, and 40 miles / 4,000ft on lower assist.
→ view post
TQ HPR50 bikes (Trek Fuel EXe, 360Wh) — if "SL" means the lightweight TQ camp:
@Emailsucks98 did 1,187m (≈3,900ft) of climbing on all singletrack in trail mode, finishing with battery to spare — on a mulleted EXe with a coil shock and DD tyres, so not exactly a featherweight build.
→ view post
The rough rule of thumb:
• A 320Wh SL battery alone → ~2,000–2,500ft of real climbing
• Add one range extender → roughly +50–70%
• 360–630Wh SL bikes → 3,500–4,000ft is achievable if you keep assist modest
The big levers in your control:
Weight — every kilo of you, bike and kit costs vertical metres
Assist mode — Eco/Trail will nearly double an all-Turbo figure
Terrain — steep tech burns Wh far faster than steady fire-road grinds
Tell me which SL you're actually on — Levo SL, Rise, EXe, something else — plus your weight and whether you've got range extenders, and I'll give you a proper tailored estimate instead of a spread.
    676K
