Levo SL Gen 1 Levo/Creo SL Chain Ring Spider Loosened
brizi2003
235
144
Whickham, Newcastle upon Tyne
I noticed the chain ring on my 200 miles from new Creo SL had some play. On closer examination the chain ring carrier retaining clip didn't seem properly located in the groove but the retaining bolt was tightened to torque spec. I removed the chain ring spider completely, refitted the clip and retorqued the bolt to spec. Now all seems good, but I'm wondering if anyone else has had a similar experience?
FireWithin
13
Montreal
Any slight play in the bottom bracket when wiggle in the green arrow direction (see picture) using both hand on each crank arm?
Thanks for some feedback.
brizi2003
235
144
I had another problem with my Creo SL crank 'clicking' when pedalling uphill under load with or without motor assistance. Turned out to be the un-greased motor/frame interface. Lesson learned: Grease the motor/frame interface and re-torque the motor mount bolts once in a while.
