Ok great thanx I will get the app and try it outMost people with 2019 Kenevo's set their local to Uzbekistan, where it's ok to do 45kph out of the box.
Assuming it's a standard Kenevo "X-wing" from 2019 with a 1.2 or 1.3 motor (comp or expert) then yes, you should be able to use blevo to configure your assistance "limit". It effectively changes the wheel size. So the bike mileage will be incorrect.
Keep in mind if you set it too high and go flat out in turbo all the time, there's a good chance you'll damage the belt in the motor if it gets too hot. Keep your cadence high, the brose hates low cadence for longevity.
