Ok thanksIt is not possible for consumers to access that information. You will have to send the battery to YT. It is one of the most frustrating things as charge cycles or capacity left is important to know.
A "charge cycle" is 100% use of the battery .What I don't know exactly is what counts as a charge cycle. For example if I charge from 60 to 100% and from 10 to 100% do both count as a charge cycle?
If you did 10 rides, that would give you 13 charge cycles. But you only used 70% of your battery on each ride.In that case considering that I return back with 30% of battery 1.3x number of rides = battery charge cycles at least in my case.
To simplify the maths If I use 50% in every ride and a full charge cycle is 0 to 100% then I need 2 rides for 1 full charge cycle.If you did 10 rides, that would give you 13 charge cycles. But you only used 70% of your battery on each ride.
Therefore, wouldn't you want to use 0.7 * number of rides ?
