Kenevo Gen1 Fox X2 fitting
JMP85
23
Glasgow
Hi all, just received my X2 and attempted a test fit to my Kenevo expert 2021 S3. Couple of questions.
Does anyone know what spacers/bushing I need for the top eyelet?
Also on full compression it is touching the frame. I have heard of people fitting a 1mm spacer. Any details on where to buy and how to fit?
Finally, I assume it is just the flip chip on the lower eye (same as the Rockshox)?
Thanks all.
salko
1,239
836
SLO
Answer on the last question: yes, there is only a flip chip in the eyelet towards the rear of the frame ...
On which part it is hitting the frame? Any picture?
salko
1,239
836
SLO
Then remove the water bottle or use smaller one ...
But you said it is touching the frame on full compression ...?
JMP85
23
Glasgow
I have fitted different size spacers either side of the bushing. It’s moved the shock 1mm away from the frame and seems to have really helped. Guess I will just need to try it.
I’ve added photos Incase someone else has the same issues.
6140C76E-A357-4072-A231-88CFC59C7495.jpeg 80C23556-5A5E-4A29-9CF4-623D4454C94A.jpeg
salko
1,239
836
SLO
Oh, yes ... it seems there is no other option than this what you did ...
