Levo SL Gen 1 Fitting the invisiframe kit
chrismechmaster
805
411
Newbury
Evening all
so I started fitting the invisiframe kit to the sl all is going well
the bike has a down tube protector on it already
Is it best to remove that or leave it and invisiframe over the top of it ??
Many thanks
Chris
chrismechmaster
805
411
Newbury
Thanks that’s what I thought I was just worried in case there was any reason why it couldn’t be doubled up
Cheers
drm31078
75
31
Charlotte, NC USA
About to install this. Does the tcu get removed to install the top tube section? Does the chainstay guard get removed or does it stay in place? Any other parts of the bike that might need to get removed?
chrismechmaster
805
411
Newbury
Tcu stays in place
Chain stay protector needs to be removed
Chain guide stays in place
All the best
chrismechmaster
805
411
Newbury
When you remove the rear wheel There one small screw just remove that screw and the rubber stay protector pulls straight off
just be careful what you re fit it after You have fitted the invisframe kit not to snag the invisframe
chrismechmaster
805
411
Newbury
Most will say yes leave it on BUT I didn’t I removed mine and it fitted so much better as no lump where it goes over the top of the other
I would defo remove it
Use a hair dryer and it peels off in seconds
DarrenCC
59
21
Hertfordshire
From memory, the mud flap behind the motor and above the main pivot needs to be removed. Carefully lift the flap to find the two screws underneath
