ENDURO FLYON 8.0 HANDLEBAR
saione
33
19
Lerici
Hi.
I would need to know the rise of the handlebar of HAIBIKE ENDURO FLYON 8.0.
I'd like slightly increase it.
Sidepod
584
395
Oxford
Stock bars are 20mm rise. I’d be wary of swapping the bar’s. It involves taking the display apart and disconnecting the control cable from the PCB inside the display I destroyed one connector doing this. A new controller with cable and connector is £100 .
saione
33
19
Lerici
Stock bars are 20mm rise. I’d be wary of swapping the bar’s. It involves taking the display apart and disconnecting the control cable from the PCB inside the display I destroyed one connector doing this. A new controller with cable and connector is £100 . View attachment 59903
Thanks for your suggestions.
Are cables and connectors present only in the central display?
Is the commanding controller/switch on the left side of the bar wireless or wired (internally)?
Thanks for your help.
Stefano
Sidepod
584
395
Oxford
Stefano
The switch on the left is wired into the controller but the cable is routed inside the bars which is why the display unit needs to be disconnected. It is a real pain in the arse.
saione
33
19
Lerici
Thanks again.
Would you be so kind to post pictures of the holes for cables in the original handlebar?
Thanks.
Stefano.
Sidepod
584
395
Oxford
So the cable routes under the grip, inside the bars and exits in the middle before going to the display.
The problem is the tiny connector on the end of the cable is very fragile and easily broken when removing from the display.
I broke it the first time I did it so had to buy a whole new control switch!
The second time I did it (on a different bike) I simply snipped the cable leaving the display untouched. When the new bars were fitted I just re-soldered the cable (six cores) and taped it up.
saione
33
19
Lerici
View attachment 60600 View attachment 60601 View attachment 60602
Many thanks for your help!
