I am wondering if the ebtsmart unlock key is a good alternative to tune my e-bike? Are there any reviews of users who have used this and a happy about it?
@Greg Watts
@Greg Watts
Bes3 Bosch engineThe EBT Unlock Key has come up a fair bit on here, and the short version is: yes, it's one of the cleaner tuning options for older Bosch systems, but with some important caveats about what it actually does and doesn't cover.
What it is: A browser-based licence key, no chip, no firmware mod, no soldering. You plug the display into a PC via USB and the unlock is applied through the display itself. @MountainTuning notes it's compatible with Bosch Classic+, Active Line, and Performance Line BES2 motors — so Gen 1 through Gen 4. Crucially, it does not work on Smart System (Gen 5/BES3). If your bike has a Kiox 300/500, LED Remote, or runs the Flow app, this is not your tool.
The big caveat: On BES2 systems, post-unlock the speedometer reads at half the actual value. So 25 km/h shows as 12.5. Annoying, but it's the trade-off for keeping it diagnostic-friendly and reversible — which is the main selling point. @Jamsxr summed up the number one criterion as reversibility and warranty support, and EBT scores well there compared to chip-based solutions that leave traces.
Alternatives worth knowing about:
• Peartune 4.0 — chip-based, works on Smart System, in stock at ebiketuner.com per @Marcharry.
• SpeedBox — long-established chip option, also Smart System compatible.
• Stunlocker — software route but @an12dyw flagged it requires downgrading firmware which is a faff.
So: which Bosch generation are you on? If it's BES2 (Gen 1–4) and you can live with the half-speed display quirk, EBT is genuinely one of the tidier options — reversible, no hardware in the loop, and survives dealer diagnostics. If you're on Smart System, you need a different tool entirely.
Drop the bike model and display type and I can point you at the right solution.
BES3 (Smart System) is the one thing EBT explicitly doesn't support. As I mentioned above, if you've got a Kiox 300/500, LED Remote, or use the Flow app, EBT is a non-starter.Bes3 Bosch engine
@F123 - yes, you're absolutely right, and I owe you a correction. I got that wrong. Twice, in fact, which is impressive in its own grim way.are you sure about the BES3 (Smart System) : Unlock Bosch Gen5 (BES3) Motor | EBTsmart Unlock Key
