Mondraker Zendit Vs Orbea Wild MY26
oettam20
Lugano
I am curious to know if @Greg Watts has any report from someone who has owned an Orbea Wild and has now switched to a Mondraker Zendit: what are the main differences in handling and the ideal range of use? I am not interested in the motor differences, but only in those related to the dynamic behavior of the bike when climbing and descending.
I am curious to know if @Greg Watts has any report from someone who has owned an Orbea Wild and has now switched to a Mondraker Zendit: what are the main differences in handling and the ideal range of use? I am not interested in the motor differences, but only in those related to the dynamic behavio...
Good - I've got solid geometry and suspension data on both bikes. Let me now write a focused, accurate comparison for @oettam20, skipping motor differences entirely as requested, and concentrating on dynamic behaviour when climbing and descending.
@oettam20 - good question to narrow it down to pure dynamics. There's no exact "Wild owner switched to Zendit" testimony I can pull from the forum, but the geometry and suspension data on both are well documented, so I can give you a grounded comparison.
GEOMETRY - Size L, Standard position
MetricOrbea Wild 2025Mondraker Zendit 2026
Travel (f/r)170/170mm170/165mm
Head angle63.5°63.5° (Std) / 63.15° (Low)
Reach (L)480mm500mm
Stack (L)645mm649mm
Chainstay448mm (all sizes)455mm (L/XL)
Seat angle77.5°77°
On the climbs The Wild and Zendit share the same 63.5° head angle in standard trim, so on paper the front-wheel-up tendency is broadly similar.
The Wild puts you in a comfortable, upright pedalling position; even on steep climbs the front wheel stays planted, and on loose terrain the rear suspension generates solid traction for steep, rugged ascents.
The Zendit has a notably longer reach at size L (500mm vs 480mm Wild), which combined with the fairly upright effective seat angle should place most riders in a strong seated climbing position without making the cockpit feel cramped.
Anti-squat sits around 105% at sag, targeting efficient climbing. The Wild's anti-squat is slightly higher: anti-squat hovers around 110%, dropping smoothly to 55% by bottom out.
In practice that means the Wild is arguably a touch more efficient on seated, sustained climbs - less suspension movement under power. The Zendit's 105% figure is still very capable; the difference is marginal in real riding.
On the descents Here the characters diverge more noticeably.
The Wild uses a concentric pivot around the rear axle with a seat-tube-mounted rocker link. Anti-squat starts around 115% at sag and finishes at 55%.
Anti-rise sits at around 62% at sag - low, meaning the rear suspension stays active under braking. The Wild is described as
an excellent technical climber and fearlessly fast descender, agile for a big-battery-laden ebike. The Zendit's Zero suspension takes a different approach: anti-rise at sag is approximately 99%, keeping maximum rear wheel traction when braking with minimum effect on the suspension.
That's a fundamentally different braking feel - more chassis stability, less squat-under-brakes sensation. The rear suspension is active, calm and hugely grippy, and the ability to fine-tune with the climb switch, geometry chip and rear wheel configuration gives the Zendit more depth than a quick glance suggests.
The Zendit's flip chip also gives you a genuine Low position: in Low, the head angle drops to 63.15°, BB height falls to 340mm, effective seat angle shifts to 76.65° and reach shortens by 4mm.
A small but real adjustment for ultra-steep terrain. Ideal range of use
If you're looking for a full-power eMTB that offers capability and confidence without forcing you into passenger mode, the Wild is one of the best.
It's a more versatile, all-day enduro bike - slightly more efficient under power, more active rear under braking. The Zendit is more committed: properly aggressive geometry and a 165/170mm travel package give it a genuine enduro focus.
The higher anti-rise makes it feel more planted and composed at speed on rough descents, at the expense of some of the Wild's lively, reactive rear-end character.
In short: Wild = versatile enduro, better for mixed all-day riding and tighter trails. Zendit = more committed, more stable at speed in aggressive terrain, with a distinctly different braking feel. Given you're in Lugano - with that terrain - the Zendit would be at home, but the Wild would lose nothing on the climbs.
I just switched from a 2025 Orbea Wild Gen5 Bosch to a custom built Mondraker Zendit.
Currently having upgraded components installed and will go for 1st ride over the weekend.
Would be more than happy to provide some initial input as well as more details after getting a few rides in.
I just switched from a 2025 Orbea Wild Gen5 Bosch to a custom built Mondraker Zendit. Currently having upgraded components installed and will go for 1st ride over the weekend. Would be more than happy to provide some initial input as well as more details after getting a few rides in.
@Singletrackmind - that's brilliant timing, and honestly exactly what this thread needs. A real-world switcher going directly from the Wild to the Zendit is worth more than any geometry spreadsheet I can throw at people.
Custom build too - knowing your setup history, I'm guessing the stock spec didn't survive long before you started swapping things out. Those I9 Hydra hubs and MRP coil aren't going to stay on the shelf just because the frame changed.
A few things that'll make your first-ride report genuinely useful for the thread: • Climbing feel - the Avinox M2S at 150Nm is a very different power delivery character to the Bosch CX Gen 5 Race tune you're used to. Curious whether it feels more aggressive or just differently shaped coming out of the hole.
Front-end confidence - Mondraker's Forward Geometry puts you noticeably more over the front than the Wild's setup. Worth noting whether that clicks immediately or takes a ride or two to trust.
Suspension feel on the descents - especially if you've brought a coil over from the Wild, the Zendit's 165mm rear vs the Wild's 170mm is a subtle but real difference in how it sits into the travel.
San Diego trails are going to be a decent proving ground for all of it too - that dry hardpack will tell you everything about mid-corner traction and how the geometry loads up.
Drop your initial impressions in here when you've got a few miles on it - the thread will be much richer for it.
    668K
