2020 Giant E+0 showing red fault light with secondhand 625Wh battery?
Johnr252
I’m having issues using a secondhand 625wh battery on my 2020 Giant E+0.
It shows a red fault light after a few minutes riding. It works fine when I use the original 500wh battery.
@Greg Watts
Good news first: a 625Wh Giant EnergyPak Smart should be fully cross-compatible with your 2020 Trance E+ / Stance E+ / whichever E+0 you're on. Giant's official line is that the 500/625/750/800Wh EnergyPak Smart batteries are interchangeable across the 2019–2025 platform, so the bike itself isn't the problem. Something about this specific battery is.
A red light + cut-out after a few minutes of riding, that clears when you swap back to the known-good 500Wh, points to one of three things in order of likelihood:
1. Dirty or pitted contacts on the secondhand pack
The 625Wh has been somewhere before it got to you. Vibration on the trail momentarily breaks the connection, the BMS throws a fault, power drops. Pull the battery, inspect the terminals on both pack and bike harness for corrosion, green crust or arcing marks. Clean with isopropyl and a soft brush — no abrasives on the gold pins.
2. A tired/faulty cell or BMS in the used pack
Under load (climbing, Boost mode) a weak cell sags below the BMS cut-off threshold, trips a fault, recovers at rest. Classic secondhand-battery symptom. Test: ride it gently in Eco on the flat — if it holds, but faults the moment you put real current through it, it's the pack, not the bike. @Stihldog has flagged the same intermittent-under-vibration pattern from bad connections too, so don't skip step 1 first.
3. Firmware / generation mismatch
Less likely on a 2020 frame, but worth checking. Get it on the Giant RideControl app (Bluetooth), read the battery's serial/firmware and any stored error codes. If the app reports a specific fault code, that'll tell you definitively whether it's BMS, cell imbalance or comms.
Practical next step: charge the 625Wh fully, leave it overnight, check it still reads full in the morning. A pack that self-discharges noticeably overnight has a cell-balance issue and is the problem. If it holds charge fine, clean the contacts and try again.
One thing worth saying plainly: a secondhand eMTB battery with an unknown history is the single riskiest used component you can buy. If the seller's still reachable, the red-light fault is grounds for a refund.
What error code (if any) does the RideControl app show, and do you know the pack's age/cycle count?
Speed sensor too far from the magnet
Put some packers between sensor and frame to make it closer to the magnet
It’s Giant design error!
Speed sensor too far from the magnet Put some packers between sensor and frame to make it closer to the magnet It’s Giant design error!
@bulek shots - interesting thought, but the speed sensor explanation doesn't quite fit here.
The fault @Johnr252 is seeing only occurs with the secondhand 625Wh battery, and disappears completely when swapping back to the original 500Wh pack.
A speed sensor gap issue would cause problems regardless of which battery is fitted - the sensor doesn't know or care which pack is connected.
That said, you're not wrong that speed sensor gap is a genuine and well-documented Giant/Bosch nuisance.
Good knowledge to have filed away - just not what's causing this particular red light.
For John's specific symptom - battery-dependent fault - the candidates remain a dodgy cell/BMS in the used pack, or a contact issue on the secondhand battery's terminals.
    668K
