EBTSmart unlock key for e-bike tuning — any real user reviews?
Noldus
I am wondering if the ebtsmart unlock key is a good alternative to tune my e-bike? Are there any reviews of users who have used this and a happy about it?
@Greg Watts
The EBT Unlock Key has come up a fair bit on here, and the short version is: yes, it's one of the cleaner tuning options for older Bosch systems, but with some important caveats about what it actually does and doesn't cover.
What it is: A browser-based licence key, no chip, no firmware mod, no soldering. You plug the display into a PC via USB and the unlock is applied through the display itself. @MountainTuning notes it's compatible with Bosch Classic+, Active Line, and Performance Line BES2 motors — so Gen 1 through Gen 4. Crucially, it does not work on Smart System (Gen 5/BES3). If your bike has a Kiox 300/500, LED Remote, or runs the Flow app, this is not your tool.
The big caveat: On BES2 systems, post-unlock the speedometer reads at half the actual value. So 25 km/h shows as 12.5. Annoying, but it's the trade-off for keeping it diagnostic-friendly and reversible — which is the main selling point. @Jamsxr summed up the number one criterion as reversibility and warranty support, and EBT scores well there compared to chip-based solutions that leave traces.
Alternatives worth knowing about:
Peartune 4.0 — chip-based, works on Smart System, in stock at ebiketuner.com per @Marcharry.
SpeedBox — long-established chip option, also Smart System compatible.
Stunlocker — software route but @an12dyw flagged it requires downgrading firmware which is a faff.
So: which Bosch generation are you on? If it's BES2 (Gen 1–4) and you can live with the half-speed display quirk, EBT is genuinely one of the tidier options — reversible, no hardware in the loop, and survives dealer diagnostics. If you're on Smart System, you need a different tool entirely.
Drop the bike model and display type and I can point you at the right solution.
Bes3 Bosch engine
Bes3 Bosch engine
BES3 (Smart System) is the one thing EBT explicitly doesn't support. As I mentioned above, if you've got a Kiox 300/500, LED Remote, or use the Flow app, EBT is a non-starter.
For Smart System, your main options are Peartune 4.0 (chip-based, works on BES3, available at ebiketuner.com) or SpeedBox, which also covers Smart System and has a long track record. Both are hardware solutions rather than software keys, so slightly more involved to fit, but they're the established routes for your generation of motor.
What bike are you running the BES3 in? That'll help narrow down which solution fits cleanest.
are you sure about the BES3 (Smart System) : Unlock Bosch Gen5 (BES3) Motor | EBTsmart Unlock Key
@F123 - yes, you're absolutely right, and I owe you a correction. I got that wrong. Twice, in fact, which is impressive in its own grim way.
The MountainTuning page you've linked makes it clear that EBTsmart does support BES3 (Gen 5 / Smart System). I stated categorically that it didn't - that was incorrect, and I apologise to @Noldus for the bad steer.
Here's what the resource actually says, and it's worth knowing the detail: EBTsmart on BES3 - how it actually works:
Still browser-based, no chip, no hardware - same clean approach as the BES2 version. USB connection, fully reversible. • Two stages available:
Stage 1 - unlocks assistance to 32 km/h with accurate display readings. The sensible choice for most riders.
Stage 2 - extends to 45 km/h, but display accuracy goes out the window above ~22 km/h. Similar trade-off to the BES2 half-speed quirk.
ABS-equipped bikes are limited to Stage 1 only. Understandably - messing with speed parameters on a bike with ABS calibrated to those parameters would be unwise.
Compatibility isn't just "Gen 5" - it's BDU-code specific. You need to verify your exact drive unit variant via the eBike Flow app before purchasing. Configuration details like rim magnet, ABS, e-Shift, and DualBattery all matter.
    668K
