Dual Crown Fork - Problems
MTB_MIKE
98
95
Southern California, USA
Trying to fit a RS Boxxer 29er, 46mm offer fork on the Decoy. Changed the Air spring to 180mm and purchased a 1-1/2 to 1-1/8 headset adapter to be able to run a 1-1/8” Straight steerer tube through the headtube but the stopper thing is blocking everything from working as it should. Any ideas what to do?
MTB_MIKE
98
95
Removing that dovetail would probably fix the problem and allow a 1-1/5 headset to fit in that pocket which means there’s two of them stacked on each other. It would work and the 1-1/8 to 1-1/5 crown race that is installed on the boxxer’s steerer tube would be able to be installed.
I tried yanking the dovetail with some needle nose pliers but it’s probably pressed fitted a d possibly glued on tight :(
