Do 12 speeds still make sense for full powered EMTB's?
Been riding MTB's since 1988. Always been concerned with gearing setups especially during racing days. Recently bought an EMTB to ride with some younger friends just so they didn't have to wait for me for too long ( I only have 40% lunbg function).
So gearing became reasonably important.
I mostly ride my analogue and ride that 36x10-51. I also clip in so my power delivery and cadence will be different from the flat pedal brigade.
My Giant ( insert ridiculously long set of words for name) eMTB is lightweight smaller battery carbon frame . It came with 10-52. I ride almost exclusively on eco with the power turned down to 20Nm and the launch about the same level. I quickly discovered that the 10-52 was hardly used for the majority of riding and being a bit of a weight weenie I changed to 10-45 cassette set. We have some extremely steep sections ( ie hard to even walk up them) , but even that is doable with the 45 just by switching the power up to the next level until most of the climb is done.
( for my local trails) that an 8 speed with the 10-45 range would do the job perfectly well.
If you consider why we have slowly increased the NUMBER of gears ( as opposed to the range), it is becase humans have a relatively narrow efficient range of rpm at which they are efficient. That is above and below that range we produce less torque. The whole point of the motor is that it extends the area under the torque curve we produce up AND down. That should mean we need less gear overlap, so less gears over the same range.
Because of the way power is delivered from pedalling, flats will need more gear divisions than being clipped in , but still way less than we have with 12, or even 10 speeds.
Yes, without question with the available torque and power available to the current emtb bikes, it is possible to have fewer gears.
However, when riding beyond battery capacity in the back country I alway try to be as efficient as possible so I am not in a situation where I have a dead battery and a climb to get back. I definitely use every gear of a 12 speed to lower the load on the motor (lower battery consumption) and lower the load on the rider (higher cadence lower physical energy) so it is nice to have the wide range in that regard.
Interesting that a Tesla is a single speed transmission and goes 0 to 200 mph (model S Plaid)
Yes, with 800.000W Motor
An Stark Varg also runs with only one gear vom 0 to about 100mph, with 58.000W.
Motorcycle and Cars have strong enough motors, so a transmission is not needet. But Mercedes and Porsche show, also here a transmission, with only 2 gears, make sense for economy.
Whatever gearing the manufacturers like to put on the latest bikes it would be nice if there was a different range of aftermarket cassettes.
My first emtb in 2013 was a Trek with Sram X1 gearing. This was a seven speed 13 to 51t which had horrendous gaps between the gears. This didn’t last very long, maybe due to the cassette costing over £400.
At 79 now and lots of my rides being 30miles with up to 4000ft of climbing I could manage with 7 speeds but with a spread of perhaps 20 to 51. I haven’t been on the bottom half of my cassette as my cadence averages 75 - 80 and I don’t want to pedal downhill.
So, everyone’s comfortable gearing is going to be different, I would just like more choice.
I have thought of leaving the loose cogs off and putting a spacer in.
    677K
