2022+ Turbo Levo Charge Limit doesn't work anymore
torabora851
103
61
Sydney, Australia
It worked from the beginning, but now it just ignores the setting and charges 100% every time. Firstly I thought that this is like "However, on every 10th charge your bike will charge to the full 100%" but 4 times in a row it charges to 100%.
torabora851
103
61
Sydney, Australia
By recommendation from Spesh support, I did a factory reset. No luck, it still ignores the charge limit setting. Will try to disable it, make a full charge and then enable it.
I wonder how the battery knows about the setting? Is there some internal memory?
ThierryGTLTS
104
52
Belgium
I think there is a Coulomb counter in the battery.
For the SL batteries (Levo, Creo, Vado,...), 15 minutes of charge = 10% of charge.
So when I have to charge my battery, I calculate the time, and cut it after that time.
For example 45 minutes for 30% of charge.
That's easy, you can use a small timer if you fear to forget to cut it off :)
Have a Nice Day.
Thierry
torabora851
103
61
Sydney, Australia
Hey, @Crockej have you tried to do a factory reset? Press the + and - buttons for 45s and wait until the TCU will restart twice and you will see the "factory reset" screen. It didn't work for me.
Would be nice if you test this, so we can push the Spesh to address the problem.
torabora851
103
61
Sydney, Australia
Got this sequence from the spesh support, which fixed the issue for me:
  1. Perform factory reset.
  2. Deplete the battery to below 80%
  3. Toggle on charge limit
  4. Force close the Mission Control app
  5. Open the app and enter the tune screen to check the settings
  6. Then charge the bike and see what happens and report back to us please.
BushLevo
58
21
Melbourne, Australia
My Levo is a 2019 with the standard (blue LED) TCU. After I had the battery firmware updated I had about 8-9 charges (from around 55%) up to the charge limit of about 81% with no problem...the limit cutout worked every time. On about the 10th partial charge, the charger kept going to 100% so I let it finish charging so the charger turned itself off (green). I think you have to let the charger finish so it can balance/recalibrate all the cells in the battery.
Just in case I was going to have the same problem as you, I followed steps 1-6 above exactly and the next charge (from 62%) finished properly at 81%.
What confuses me is that Specialized say the charger will go to 100% every 10 charge cycles. This doesn't appear to be the same "Charge Cycles" that MC reports. Because I only do partial charges each time, my Charge Cycles number changed from 46 to 48 throughout the last 10 or so partial charges I have done. So I suspect that what happens is the battery firmware counts each time you charge the battery (whether full or partial), ignores the total Charge Cycles number shown in MC and forces a 100% charge every 10 charging events. I'm going to keep a careful log of all charges I do for the next couple of months to see if this is what really occurs. Also, I'm going to see if the next 100% charge event is followed by a 80% charge event automatically without having to do any resets, or charge limit toggling.
I'll be complaining loudly to Specialized Australia if there are problems with this battery firmware. The LBS I brought the bike from in 2019 charged me $50 to update the battery (and TCU) firmware in February, since you can't do your own battery update with MC.
LevoBiker
16
NJ
I started having the same problem. Doing the toggle and Force Stop process. Will see what happens.
[Update] Finished a ride at 40% charge. Charge Limit toggle was ON. Put it on the charger. I could tell it was going over 80% so I stopped the charge. Checked Mission Control. Charge Level was 95% but Charge Limit toggle was OFF !! What? I toggled it back ON. Will see what happens after ride tomorrow.
[Update] Nope, no luck.
6950rpm
20
13
Isle of Wight
My charge limit has now stopped working so before I follow the troubleshooting steps outlined above, can anyone tell me if by doing a factory reset on the TCU, do you have to pair the bike again? Is any other data lost?
LevoBiker
16
NJ
I watched this video from Specialized University () and it says 20 seconds will retain your settings for TCU 2. I also read in the Levo manual that 45 seconds will erase everything but I could not find the 20 second reset mentioned in the manual. So, what to believe?
6950rpm
20
13
Isle of Wight
I did a standard reset (hold + & - down for 20 seconds) and now the charge limit is working again.
HDC
France
Same problem here. I did try to reset the TCU / deplete battery below 80%/ force quit MC but it was not working. Battery shows 100% this morning. Will give another try over the weekend
Hopefully bug will be fixed in next firmware release.
HDC
France
LevoBiker
16
NJ
It finally started working for me. Just need to follow the steps exactly as above:
Power on bike. Connect to MC. Do the 20sec TCU reset. Wait for MC to reconnect. Toggle the Charge Setting in MC. Force Stop MC App. Restart MC and check that Charge Setting is still enabled. Power off bike. Charge.
HDC
France
It started to work as well. I followed your steps at the letter and battery load displayed 81% after loading.
Really hope Spe will fix this ;)
463K
