Chain length
Cyclejunkie
140
97
Deal Kent
Hi just up-graded my front chain ring to 36T my chain length is 116 links but the gears won’t drop into the smallest cog at the rear cassette is my chain to short can’t think of any other reason as all was ok on the 30T chain ring what chain lengths are people running please.... was thinking 122links with a 36T front ring
Pyr0
507
370
Wirral, UK
I swapped my chain for 118 links after upgrading the front chainring to 36t.
I had no issues changing gears with the shorter chain, but in the largest gear the derailleur looked like it was stretching too far and almost horizontal
8,670
Switching from a 30t ring to a 36T would normally require you to add some links to your chain so that you could access the big cogs at the back without the risk of ripping off your mech in a G-out. But it should have no effect on accessing the small cog on your cassette. You must have inadvertently altered something on your set up. Try altering your cable tension.
salko
1,241
837
SLO
Does anyone have info what is stock chain lenght on a 19/20/21 Levo size L and Eagle drivetrain with 32T chainring and 10-50T cassette? Thanks!
mrg3.6
8
Hindhead, Surrey
I'm just about to install a Praxis 36T chainring and a 12 speed 11-50T Cassette on my 2020 Levo Comp, so should I start with 122 link chain?
Thx
Martin
