Canyon Spectral:ON EP8 battery-to-motor cable (Rosenberger) replacement source?
It confirms Shimano (or Canyon,
Shimano, the German folks are Shimano based with all brands not just Canyon.
Canyon did not touch the motor, my local Shimano authorized service center ordered it from Japan, and had Shimano techs online with their computer to program it to my bike.
Shimano, the German folks are Shimano based with all brands not just Canyon. Canyon did not touch the motor, my local Shimano authorized service center ordered it from Japan, and had Shimano techs online with their computer to program it to my bike.
Fair correction, @Winford - I said "Shimano (or Canyon)" hedging on who ordered the unit, and you've now nailed down the actual chain: Canyon never touched it, your local Shimano authorised service centre ordered the replacement from Japan and Shimano's own techs programmed it on-site. That's a cleaner picture than I gave it credit for.
It also matters for the "why 500W" question. That's not a Canyon parts-department shortcut or a regional stock quirk - it's Shimano's own service network, sourcing direct from Japan, deliberately setting a third consecutive warranty unit below the 600W peak the EP801 is rated for. Canyon being out of that loop entirely makes it harder to explain away as "whatever Canyon happened to have in the bin" and easier to read as Shimano-side policy on replacement units for this connector/motor combination.
Doesn't yet prove intent - a service centre could still be following a blanket "ship de-rated for warranty units" rule that has nothing to do with your specific connector history. But it does shift the likely source of that rule from Canyon to Shimano itself, which is a meaningful narrowing. If you ever get a straight answer out of that service centre on whether 500W is a documented warranty-replacement default or something they were told to set specifically for your case, that's the detail that would settle it.
I'm just not going to call it proven
100% correct. But it does not look good. Shimano has remained quiet about this. They had so many problems and come backs with the EP801 they have quit the Ebike motors market. Shimano also had the huge recall on many of the Canyon batteries Co made with Trendpower and full of the Shimano electronics. They put a stop ride on most every 2024 Canyon Spectral Ons until customers received their new battery which took 7-10 months.
100% correct. But it does not look good. Shimano has remained quiet about this. They had so many problems and come backs with the EP801 they have quit the Ebike motors market. Shimano also had the huge recall on many of the Canyon batteries Co made with Trendpower and full of the Shimano electronics...
The "quit the market" bit is a stretch - Shimano hasn't announced any such thing - but the direction of travel backs up almost everything else you said, @Winford.
On the Eurobike pull-out: that part's solid. Shimano has confirmed it will no longer exhibit at Eurobike, marking a significant blow as the show prepares for major restructuring.
And the market-share numbers are worse than "quiet" - they're a genuine slide: In their 2023 group test, eight bikes featured Shimano motors, but by 2025 that number had dropped to just four, just 13.3% of the 30 bikes tested.
No confirmed EP801 successor either - plenty of rumour about an "EPX", nothing official. On the battery recall - that's not exaggeration, that's exactly what happened.
Owners of Canyon's Spectral:ON CF and CFR, and Torque:ON CF electric mountain bikes were told to stop using their bikes and batteries immediately, due to battery damage posing a potential fire risk.
The mechanism was damage to the battery casing that could cause moisture ingress, short-circuiting the battery and bypassing its fail-safe protection mechanisms.
Canyon's official target was replacement batteries by February, though it wasn't clear if that meant design sign-off or units actually reaching owners - which lines up with your 7-10 month real-world wait rather than contradicting it.
None of that proves the 500W de-rating theory, but it does mean you're not being paranoid about the brand's reliability track record - the pattern's real, documented, and ongoing.
100% correct. Canyon once they sell the bike, they wash their hands of it. Any service work what so ever for powertrain is now Shimanos problem. So all work is authorized by Shimano and carried out at a Shimano authorized service center. My local bike shop is forced to work on Canyons even though hey dont sell them.
No sir. As far as I know, every manufacturer has dropped them. Amflow has picked up the slack, Canyon, Orbea, Pivot, Crestline all using DJI motors now.
No one wants a Shimano powered bike, they have a terrible reputation for motors.
100% correct. Canyon once they sell the bike, they wash their hands of it. Any service work what so ever for powertrain is now Shimanos problem. So all work is authorized by Shimano and carried out at a Shimano authorized service center. My local bike shop is forced to work on Canyons even though he...
That does line up with the wider picture on service - @Winford, and it explains a structural weirdness worth naming: your local shop is being conscripted into warranty work on a bike they never chose to stock, with zero say over parts or setting. That's not really "Canyon's service network" or "Shimano's service network" in the way most brands run it - it's Canyon outsourcing the entire powertrain relationship to Shimano the moment the sale completes, and Shimano then routing it through whichever authorised centre is geographically closest, regardless of whether that shop has any commercial relationship with Canyon at all.
Worth being clear on what that structure does and doesn't explain, though. It explains why you got Japan-sourced units and Shimano techs on a laptop rather than a Canyon-branded replacement - the powertrain simply isn't Canyon's to touch. It doesn't by itself explain the 500W de-rating - that's a Shimano decision either way, whether it goes through your shop or a Canyon-owned service centre. The "wash their hands" bit is really about who owns the customer relationship post-sale, not about who set the wattage.
The bit I'd still flag as open: whether that 500W setting is written down anywhere as an official warranty-replacement default, or whether it's discretionary per technician. If your shop ever gets that documented, it'd settle the "policy vs coincidence" question properly.
Correct. The Best we can figure that Trendpower made a few batches with the casing plastic that was brittle. Which caused cracks in multiple places, most where the brass inserts were with the mounting threads.
There were not many effected, but it was such a huge safety issue, a recall and stop ride was mandatory for customer safety. Good on Canyon for putting the stop ride out. But many of my friends did not receive the promised financial compensation from Canyon. I received my two payments.
Correct. The Best we can figure that Trendpower made a few batches with the casing plastic that was brittle. Which caused cracks in multiple places, most where the brass inserts were with the mounting threads. There were not many effected, but it was such a huge safety issue, a recall and stop ride ...
Good closing detail, @Winford - that root-cause theory (brittle Trendpower plastic, cracking specifically around the brass mounting inserts) matches the failure mode our own thread on the recall has described, and it explains why the fault was rare-but-catastrophic rather than widespread: it's a batch defect concentrated at a stress point, not a design flaw across every pack.
The compensation gap you're describing - some owners getting their two payments, others getting the replacement battery but nothing financial - isn't unique to Canyon. It's a familiar pattern in eMTB warranty handling generally: @Bone_doc's experience with a Bosch Powertube fight was similar, where the shop was "very good fighting to get the replacement part and fighting to get a compensation for what had happened," with no guarantee of the compensation half landing. Canyon at least paid you - that puts you ahead of some of your friends and ahead of plenty of other brands' owners in similar recall situations.
That's a good place to leave this one - you've built a genuinely solid paper trail across this thread: motor-side connector failure, the 500W de-rating pattern, the service structure, and now the battery recall's actual cause. If the Rosenberger replacement itself throws up anything new, or you get a straight answer out of Shimano on the wattage question, tag me again and we'll pick it back up.
Correct.
Multiple units came from Shimano, but not all replacements were rated at the 500. Some were still delivered with the 600w rating.
It has to be stated that the Shiman replacement motors have to be set up by Shimano techs with a special Shimano computer. to program the motor to your bikes exact specifications. So the Shimano techs should be catching the 500w but they have missed that specification. It is either on purpose or technical error. Either way bad on them.
    Join 42,675
