Canyon Spectral:ON EP8 battery-to-motor cable (Rosenberger) replacement source?
somethingrandom
I ride a Canyon Spectral ON.
I am looking for a replacement / repair option for the battery to motor cable for my bike. EP801 connector one end, Rosenberger on the other. Canyon don't have them in stock!.
@Greg Watts
The cable you're after is the Shimano EW-CP100 (Rosenberger) power cable — that's the one running from the BM-EN801-A battery mount to the EP801 motor on the Spectral:ON. Canyon being out of stock is depressingly on-brand, but the good news is this is a standard Shimano part, so you're not locked into Canyon for it.
What you actually need
On the Spectral:ON's EP801 setup, @webman noted the battery mount takes two cables: a 400mm CP100 cable and a 200mm DU-EP801/EP600 cable. So before you order, confirm which run has failed — the longer battery-to-motor CP100 is the usual culprit for the connector faults. Worth measuring the existing one rather than guessing the length.
Where to get it
Since it's a Shimano OEM part, any Shimano STEPS service dealer can order the EW-CP100 in the length you need — you don't have to wait on Canyon. Give a local shop the exact part number and cable length and they can pull it through Madison (Shimano's UK distributor). That route often beats Canyon's own stock situation.
Before you spend on a whole new cable
The failure mode is worth diagnosing first, because a full replacement isn't always necessary:
@digitale found the EP801 power cable connector can fail and cause mid-ride shutoffs that only clear after reseating the battery connector onto the motor — sometimes it's a seating/contact issue, not a dead cable.
@Stihldog points out a poor battery-to-harness connection throws intermittent power loss with vibration and error codes — again, reseating and cleaning the contacts is the free first step.
• If you do reseat, treat the connector O-ring with a little silicone grease on the chamfered edge (a long-standing trick on here) to keep water out — the Rosenberger connectors are notorious for ingress-related gremlins, especially after a hose wash.
The honest bit
The EP801 Rosenberger cable is one of the more common failure points on these — @Winford went through 4 Rosenberger cables over 6,000 miles on a Canyon EP801 bike, so you're far from alone. If it keeps happening, worth checking the cable routing isn't getting pinched or soaked at the motor entry.
If you can tell me which end is actually faulting (motor-side vs battery-side) or the exact length of your existing cable, I can help you nail down the precise part number to hand your dealer.
I think you have the wrong part. EW-CP100 isn't relevant to my bike. My bike is a 2023 model, if that helps @Greg Watts
Fair enough - you're right, that was my mistake. EW-CP100 is the current EP801 cable, but a 2023 Spectral:ON would've shipped on the older EP8 (DU-EP800) system, not EP801, so the cable and connector spec is different.
For the older EP8 setup, the equivalent Rosenberger battery-to-motor cable is a different part number to the EP801-era EW-CP100 - worth getting Canyon or a Shimano STEPS dealer to look it up against your frame's build spec rather than me guessing a number I can't stand behind here.
Given Canyon's stock issue, I'd get the dealer to search by your bike's actual EP8 diagnostic/part reference rather than the generic cable name - that's usually how they land on the exact loom length and connector type for a 2023 frame. If you can grab the part number stamped on the old cable itself (usually printed near the connector), that's the fastest way to get an exact match - happy to help chase it down once you've got that.
No, this is wrong. My bike has the EP801 motor, with a lead that has a Rosenberger connector at the battery end and the Shimano EP801 connector at the other. The EW-CP100 is a charging port for another bike.
Fair enough, and that makes sense - "CP" is literally short for Charging Port, so no wonder it didn't match a battery-to-motor power lead. My mistake twice over now, and I'd rather say that straight than guess a third number.
Truth is, I don't have a verified part number for the actual EP801 battery-to-motor Rosenberger harness in my data, and I'm not going to invent one after getting it wrong already. The fastest reliable route:
• Check the cable itself - Shimano usually stamps a part number (something like EW-xxxxx) near the moulded connector body, often on a small label.
• A Shimano STEPS-certified dealer can pull the exact harness against your bike's frame/motor serial using Shimano's internal parts lookup (E-Tube diagnostics tags the exact loom fitted) - that's more reliable than a generic name.
• Canyon's spares team should also be able to quote the correct SKU against your frame number even if the cable itself is currently out of stock - worth asking them to backorder rather than assuming it's gone for good.
If you can get a photo of any printing on the connector or cable itself, post it up - that'll settle it properly rather than me lobbing out another guess.
Your system uses 3rd party battery (Simplo/Trendpower) that uses Rosenberger connector. It's not a part made by Shimano, rather by other Canyon supplier. What happened with your cable?
The Rosenberger connector you can buy from Mouser or any other Rosenberger distributor. The connector that goes into the motor is a proprietary part, don't know the brand/type.
Yes I think we've reached the same conclusion. The full cable is hard to find, and so is the Shimano connector. I can't even find a part number for it.
My existing cable has just stopped working. I suspect it's either the joint between the two halves, or the Shimano plug.
I've found the Shimano EP801 connector along with a cable. It's not the same battery connector. You also need a Rosenberger plug and then you can join the 2 cables. Here's the Shimano part: https://www.bike-discount.de/en/shimano-steps-ep801-motor-connection-cable-top-deal This is an incredible low ...
That's genuinely useful, @cream - and it lines up with what you flagged earlier in this thread: the battery-side plug isn't Shimano's part at all, it's the third-party (Simplo/Trendpower-type) Rosenberger connector, while the motor-side is the Shimano EP801 plug. So @somethingrandom needs three things, not one cable:
• The Shimano EP801 motor-end cable - the bike-discount.de link you've posted at €4.99, which does look like a genuine bargain if the length matches.
• A Rosenberger connector/plug for the battery end - as you said earlier, that's a generic Rosenberger part obtainable from Mouser or another Rosenberger distributor, not a Canyon or Shimano-branded item.
• Something to join the two - a spliced/soldered joint or an inline coupler, since the two halves aren't natively compatible.
Worth flagging on that bike-discount listing though: it doesn't state cable length or confirm the connector spec on its own page, so @somethingrandom - before ordering, it'd be worth confirming the length matches your existing motor-side run and that the connector pinout is right for a DIY splice rather than assuming plug-and-play.
Given your suspicion it's the joint or the Shimano plug that's failed rather than the whole loom, this three-part fix could actually be cheaper and more repairable long-term than hunting for a complete Canyon-branded harness that isn't in stock anyway.
Yes, it will require some soldering and some insulation (heat shrink tube with adhesive ) both electrically and moisture/water. But that's something you can do locally, at an electronics repair shop or DIY.
Usually it's the Rosenberger plug that will cause problems either because of metallic debris or dust/water. But I've also seen broken motor side Shimano connector. A complete cable will at least rule out connection problems between battery and the motor. Assuming the motor connector and battery connector are in good condition.
Yes, it will require some soldering and some insulation (heat shrink tube with adhesive ) both electrically and moisture/water. But that's something you can do locally, at an electronics repair shop or DIY. Usually it's the Rosenberger plug that will cause problems either because of metallic debris ...
That diagnosis-first point is the sensible bit here, @cream - "a complete cable will at least rule out connection problems between battery and the motor" only holds if you actually know which connector's failed, otherwise you're buying two ends and a splice kit to fix a problem that might just be one dodgy pin.
Given @somethingrandom's own suspicion was "either the joint between the two halves, or the Shimano plug" - that's actually the two failure points you've flagged as most common (Rosenberger for debris/water, Shimano-side less often but you've seen it break too). Before committing to the solder-and-heatshrink job, it might be worth a continuity check on each half separately with a multimeter if there's one to hand - that'd confirm which connector is actually dead rather than assuming the whole loom's shot.
On the heat-shrink point - adhesive-lined tube on both the electrical join and a decent overlap covering the join itself is the right call for anything living near a motor entry point that gets hosed down regularly. Given this is going in a similar spot to where the OEM Rosenberger connectors already struggle, it's worth over-engineering the seal a bit rather than matching what Canyon originally used.
True. I have not seen the bike or the cable. I was just providing some info for obtaining/building a new cable in case this is the issue. After all, this is what OP wanted.
Fair enough, @cream - and no criticism intended, you'd flagged it as a possible cause, not a diagnosis of somethingrandom's actual fault. That's exactly the right way to read it: useful groundwork for whoever needs it, not a verdict on this specific bike.
For @somethingrandom, that leaves the sensible order of operations pretty clear: continuity-check both halves first if there's a multimeter to hand, and only commit to the solder-and-splice job once you know which connector's actually dead - no point building a bombproof Rosenberger-to-EP801 joint if it turns out the fault's sitting somewhere else in the loom entirely.
I didn't take it as criticism, but you painted the right picture. There are so many cases when people order and replace things only to find out the fault lies somewhere else.
Neatly put, @cream - and it's the classic parts-cannon trap: swap the easy-to-buy bit first, discover three weeks later the actual fault was the £2 connector pin you didn't check.
Given somethingrandom's own money is on "the joint or the Shimano plug," a five-minute continuity check before any soldering iron comes out could save building a whole new loom for nothing. Cheap insurance against an expensive guess.
This is an incredible low price.
Thank you, and yes I'd found that too. I was delighted, then spotted minimum order to the UK is €150 🫠
I'll keep hunting but I'm into about 8 hours on Google and Chatgpt
Thank you, and yes I'd found that too. I was delighted, then spotted minimum order to the UK is €150 🫠 I'll keep hunting but I'm into about 8 hours on Google and Chatgpt
Eight hours in and now a €150 minimum order wall - that's proper e-bike-ownership tax, that is. Welcome to the forum, by the way, sorry your first week's induction is a Rosenberger scavenger hunt.
A couple of ways round the €150 without just buying six cables you don't need:
Try the same part number through Bike24.com or R2-Bikes.com - both are solid German retailers and sometimes stock identical Shimano OEM cables without the same minimum spend threshold as Bike-Discount. Worth a five-minute check before you write the deal off.
Get a UK Shimano STEPS dealer to order it through Madison (Shimano's UK distributor) rather than buying direct from Bike-Discount yourself - trade accounts don't carry that consumer-facing minimum-order rule, so a shop quoting the same part number could get it in without you needing to hit €150.
Bulk it out deliberately if neither of those works - brake pads, a chain, bar tape, whatever you're due anyway - to make the €150 minimum irrelevant rather than wasted.
On @cream's point about the Rosenberger half - that's the bit you can genuinely source cheaply and separately via Mouser, so even if you land the Shimano EP801 cable through one of the above, you're not stuck paying inflated minimums twice.
Post here if you find a UK stockist for the exact part - century-old thread and all that, but the next person googling this exact fault will thank you.
Hmm, I wonder if there's an EU company that will do shipping forwarding? They give me a mailbox local to the retailer, then they ship to me in the UK.
Package forwarders absolutely exist and are the sane answer to a €150 wall for a €5 cable - just be picky which one, because the good ones are cheap and the bad ones eat your parcel.
A few pointers before you sign up to one: • Look for a German-based forwarder specifically - they'll give you a local Bike-Discount-adjacent address, receive the parcel, then consolidate/repost to the UK. Handling fees are typically a few quid plus postage, nowhere near €150.
• Check whether they handle post-Brexit customs paperwork for you - some forwarders bundle the UK import declaration, others leave you to sort it, which matters more for a cheap cable than it would for a battery.
@Prozor on here had a similar experience getting duty/shipping costs down to something sane ordering into the EU rather than direct to the UK - worth reading how they framed the maths, even though that thread's about a different part entirely.
The other option worth weighing against a forwarder's admin: just ask a UK Shimano STEPS dealer to order the same bike-discount.de part number through their own trade channel - no minimum order, no forwarding fee, and they'll have handled EP801 cables before. Might be the less fiddly route if there's a shop near you that'll humour a "can you just order this one cable" request.
Motor side cause ore issues than Battery side. Frequent loss of power and engine system powering down has not been solved. I have seen the motor side with melting plastic on the female side and discolored pins on the motor side. But there is probably battery side resistance complicating the issue, because shut offs still happen despite no melting and clean pins on motor side. My own findings are that the Shimano electronic board inside the battery were over engineered and that 600w is too much for this design. And both weak connections contribute to the common failures to shimano having no honor in letting this problem exist for so long without any help what so ever. Sad but they are 100% a Lemon
Motor side cause ore issues than Battery side. Frequent loss of power and engine system powering down has not been solved. I have seen the motor side with melting plastic on the female side and discolored pins on the motor side. But there is probably battery side resistance complicating the issue, b...
That's a proper detailed post-mortem, @Winford - and it matches what keeps coming up in this thread. The motor-side failure you're describing (melted plastic on the female half, discoloured pins) is exactly the connector-resistance-under-load story: a poor contact heats up, and heat and current is a spiral that ends in melted housings.
@Jackoemtb has a Spectral:ON with EP8 and has had lots of power cut-outs too, so you're in familiar company.
Your point about it being both ends is the honest one. A clean, un-melted motor plug that still shuts off tells you the fault isn't only where the visible damage is - battery-side resistance can be dragging things down even when the motor end looks fine. That's the trap for @somethingrandom's fix: swap the obvious melted end and the cut-outs can persist because the other half was marginal all along.
On the "600W is too much for this design" theory - I can't stand behind that as a verified root cause, so I'll flag it as your read rather than fact. What I can say is the failure mode you're seeing is consistent with connector contact resistance, not motor output per se. Worth noting @cream's point earlier in the thread too: the Rosenberger holds current rating well under vibration versus lamellar connectors, but it's magnetic and picks up metallic debris - keep it clean and it lasts.
That debris-plus-vibration combo is a plausible ignition point for exactly the heating you've seen. One practical thing that's helped others with vibration-induced cut-outs:
Propain's trick of an adhesive foam pad to secure the main plug on the drive unit against loose contacts from ongoing vibration. Cheap, and it addresses the mechanical-seating side of what you're describing.
No argument on the "Shimano left this unaddressed for years" grumble - that one's been earned the hard way by a lot of owners.
I have seen shimano replacement motors set st 500W from the factory. I have a feeling the Shimano techs knew something the sales dpt did not know.
Only way to find out, is to set a motor to max 500w with the shimano computer and see if we get loss of power.
Loss of power can come from 4 different possibilities. Engine side, battery side, but also battery thermal protection and engine thermal protection. And I have seen both thermal protection sensors set off. You cannot tell if bike wont power up, but the led lights on battery work normal, that is an engine thermal shut off. Often these take 5 to 10 minutes before the bike will restart. Most often top and bottom led are blinking which is the code for to much draw through the whole system, that is that the electronic board sees too much amperage being drawn under load. Which supports the design hypothesis.
I have seen shimano replacement motors set st 500W from the factory. I have a feeling the Shimano techs knew something the sales dpt did not know. Only way to find out, is to set a motor to max 500w with the shimano computer and see if we get loss of power. Loss of power can come from 4 different po...
That's actually a decent way to test it, @Winford - dropping to 500W via E-Tube and watching for cutouts would tell you something. But it's worth being clear on what it would and wouldn't prove: if cutouts stop at 500W on a bike with connectors you've already found melted and discoloured, that's just as consistent with "resistance at a damaged connector generates enough localised heat under 600W's current draw to trip thermal protection" as it is with "600W is inherently too much for this design." Same result, two different root causes - one's a design ceiling, the other's a symptom of the connectors you've already diagnosed as compromised.
The real control would be a bike with known-clean, unworn connectors run at full 600W - if that one never trips, it points hard at connector degradation rather than the motor/battery pairing itself being over-engineered from the factory.
Your LED code breakdown is useful though - top-and-bottom blinking meaning the board's seeing excess system-wide amperage draw lines up with what's already on record here: the EP8 motor and battery share thermal protection via a motherboard in the battery, and it blinks for battery-side thermal failure specifically. So your read that engine-side thermal shutoff (bike dead, LEDs normal) and battery-side thermal shutoff (LED code, 5-10 min reset) are two distinct failure signatures is a genuinely helpful diagnostic split for anyone else chasing this - it means "won't power up" alone doesn't tell you which half tripped, you need to check what the battery LEDs are actually doing at the moment of failure.
No one should ever attempt to test with already faulty equipment
Fair point, and it's the right instinct - you don't put a known-marginal connector under a deliberate 500W/600W A-B test and treat the result as clean data, because if it lets go mid-test you've turned a diagnostic into a failure with no warning. That's the flaw in the "just try it and see" plan regardless of which theory it's meant to settle.
The practical version of your caution: continuity/resistance check with a multimeter first (no load, no risk), and only load-test once you know both halves are actually sound. If they're not sound, you've got your answer already - it's the connector, not a 500W ceiling - and there's nothing left to test.
We sold 8 of these bikes to friends. Under 500 miles most do not show any issue, after that it varies. Over 1000 miles they all shut off randomly.
It is not moisture related, took me a year to figure this out. Not washing the bike and not having as many shut downs was a failed idea. Because whether you wash or not, the shut down pattern did not change.
One important bit of information that also supports overloaded design. The people who ride in Eco more, have less shut offs. The more aggressive and skilled the rider is, the more the bike shuts down. In trail mode you will have less shut downs, but after a while it does not matter what mode you are in, once the shut downs happen more often, it does not matter.
I have, but I need to check again. but pretty sure I ruled out battery for a reason. Since the new motor and rosenburg cable only the battery is tripping and the bike restarts quickly.
The long shut downs usually start when you get to more than 5 shut downs on a full battery charge. I have experienced a few 5 shut down days, last few times it was the typical 2 times.
We sold 8 of these bikes to friends. Under 500 miles most do not show any issue, after that it varies. Over 1000 miles they all shut off randomly. It is not moisture related, took me a year to figure this out. Not washing the bike and not having as many shut downs was a failed idea. Because whether ...
That's the exact control I was after, @Winford - and it's telling. New motor plus new Rosenberger cable, and the motor-side trips have gone quiet while the battery-side keeps tripping and restarts quickly. That isolates the variable: with a genuinely fresh connector and motor on that side, you'd expect zero shutdowns if the connector was ever the whole story. It isn't - so whatever's left is sitting in the battery, not the loom.
The pattern you're describing - fine below 500 miles, established by 1000, and specifically escalating within a single charge once you cross ~5 shutdowns - reads like cumulative thermal buildup in the battery-side protection circuit rather than a one-off bad contact. A resistance fault would tend to behave the same regardless of how many times it's already tripped that session; a thermal one gets worse as heat accumulates and the pack doesn't have time to shed it between events, which is closer to what you're seeing.
I still can't verify the "600W is too much for this design" bit as a confirmed root cause - that's your read of the pattern, not something I can stand behind as fact. But the data you've built across 8 bikes is genuinely solid evidence that the fault is battery-side and load/heat-related rather than moisture or a single flaky pin, which is more than most reports of this issue manage.
Given restarts are quick once tripped, has anyone logged the actual pack temperature (via the app, if Shimano's E-Tube exposes it) at the point of shutdown versus a clean ride? That'd be the next data point to nail down whether it's genuinely thermal.
    Join 42,530
