ricericebaebae
Before I dump a few dollars and find out it won't even ever fit at all, has anyone tried fitting a full on chain guide (i.e. with a lower pulley/guide block and upper guide) onto a CX Gen 4 motor?
I attached two pictures showing an E13 eSpec guide for a CX motor with an alloy chainguide plate back spacer for an ISCG 05 E13 guide I used to have.
The reason why I asked the question in this thread is that when you overlay the ISCG 05 backplate spacer onto the Bosch specific guide, the ISCG 05 bolt pattern seems to be right there if not, pretty close. I just don't want to waste the money if someone has already tried as I don't have any other subsequent use or re-use for an ISCG 05 DH guide if it doesn't work.
Thanks in advance.
Thanks in advance.
