Bearing of a derailleur pulley
Sander23
726
454
Belgium
1 of the bearing of my sram ex1 derailleur seems to be broken. Is it possible toch change the bearing on itself? The theeth of the pulleywheels are still in great condition.
If so wich one do I need?
Jackware
Fat-tyred Freakazoid
1,930
2,090
Lancashire
looking at the Sram spares site they don't appear to be a spare part. Probably easier to buy a a new pulley set.
BikeInn show them in stock;
Ted
56
84
California
You could try removing the dust caps from the jockey wheel, pulling the bearing seals, cleaning out the bearing, repacking with grease, and putting the seals back on. It is easy and worked for me.
Sander23
726
454
Belgium
I doubt it will work, there is so much movement between the pulley and the bearing
Sander23
726
454
Belgium
This is the pulley. Seems done or is it still ok the bearing on it own( if I can find it)?
RustyIron
1,581
2,466
La Habra, California
There is obviously a lot of wear on the side of the pulley wheel. There's a washer-like dust cap that should go there. Was the pulley installed with both washers? Maybe the washer was missing, or maybe muck just got in there and started grinding away. Regardless of the condition of the bearing, I'd replace the whole set.
Sander23
726
454
Belgium
Do I have an alternative to the original? I have no clue is 8 and 12 speed is the same or different?
Kliman
7
12
Farnham, Surrey
These jockey wheels look the same as my 11s gx. In any event, the bearing spec is in your photo - 626 LLU. Here’s one link -
The bearing will push out of the plastic wheel easily with care.
I’ve done it more than once.
Sander23
726
454
Belgium
But is the wheel itself still good? The thooth are almost new, the site of the wheel seems like it been works
Kliman
7
12
Farnham, Surrey
They look good enough to punt a few quid on some cheap bearings, considering the alternatives. Amazon might do them cheaper. Their use and location kind of renders these bearings kind of sacrificial, you can’t keep the grit and sh*t out!
James_C
474
229
Kent, UK
these are worth keeping an eye on. If the seize, it can smash up the whole mech, as happened to me.
I check regularly and replace bearings when they get gritty now. About 6 weeks apart last time :-O
I buy the bearings 10 at a time. I personally wouldnt use cheap ones, you want decent seals, although im not sure how much difference it actually makes.
530K
