Unanswered Anybody purchased & fitted aftermarket range extender/battery to fit bottle bosses?
Dawdling68
10
South East UK
Thinking of fitting a 250/300wh waterbottle sized range extender/anxiety battery to my Scott Genius 2021.
Saw these HERE
Wondered if they were feasible, with the idea of placing a Bosch compatible plug with a short cable to plug in charging socket on bike. I have a very little knowledge of electrics & cabling, so please be gentle with any answers.
H.E.
55
281
the mountains
I did not, but Scott Designet this Frame so you are able to fit a Bosch 500WH External Battery in the Triangle
AFAIK you will need the Scott Range booster Adapter Plate the Bosch Battery and a Y Cable also from Bosch.
The Scott Dealer should be able to get this done.
Dont plug this battery in the charging port.
Dawdling68
10
South East UK
Thanks. I've seen the feed ref. the Scott/Bosch range extender. That's £750-£800 + fitting & it's permanent. I was looking for something more plug'n'play, like the SL EMTBs have such as Rise & Levo SL.
