On my new STEPS 8000 equipped Ebike l find the motor engagement is a bit harsh when in TURBO mode.
As in, it's not very smooth, the power comes in a bit jerky. It's OK once engaged and as long as you don't stop pedalling.
ln the lower power modes it's alright.
TURBO is currently set at "high" which l am going to turn down and see if it's any better, but doing that reduces the assistance from 300% to 200%
l just wondered if this was normal for this motor, l rarely use "TURBO" and will live with it if it's normal.
Current firmware is 4.8 l wonder if installing the 4.9 firmware (introduced in Oct 2020) improves it?
l've resisted updating it because then the Stunlocker app will no longer work. But l will update if it will cure the engagement issue.
