Lime-Kenevo
After pouring through the threads here looking to upgrade the 32T to a 36T chainring on a 2018 Kenevo, it looked like it was possible with examples of 2018 and 2020 models of Levo and Kenevo:
The general consensus was that even with medium sizes there was still clearance with the chainstay and it wouldn't interfere.
I went with a Wolftooth 36T 104BCD (Drop-Stop A) on the advice of Tori and VaseLEVO:
Here's the exact one:
104 BCD Chainrings
I installed it with the crank on using 1x bolts and there's no way a 36T will fit here. It's pretty much touching the chainstays on my XL frame. The only way is to ramp up the preload on the spring to get enough clearance so that it'll fit, but even then it's less than a credit card of distance.
Anyway, no hardship really, just thought I'd leave this here as a precaution to anyone else following the same advice on these threads. Fitting seems to be specific to which model (Levo/Kenevo), frame size, and gen/year of manufacture. There might even be something in it with the different tooth profiles (Drop-Stop ST for Shimano 12-speed Hyperglide+ chains, Drop-Stop A for SRAM Eagle and everything else).
That said, if i'm missing something to get the 36T to fit.... let me know?
Largest Chainring on a 2020 Kenevo? - EMTB Forums
Question in title. I see 36 is consensus on the 2018 Kenevo. How about the all new frame? Can a 38 fit? I'll be asking a few questions in the next few weeks as I fix up the kenevo spec to my liking. :)
www.emtbforums.com
Kenevo chain ring size - EMTB Forums
Hi all, we have just bought a pair of Kenevo's from Rutland Cycling , the store manager suggested we upgrade the chain ring from the standard 32 to a 36 tooth based on most of his customers eventually requesting this after a few rides. Can I assume the 32 standard makes the gears slightly...
www.emtbforums.com
Chain ring size? - EMTB Forums
Just asking for any experience from Levo owners. I'm finding the standard 32 tooth front chainring does tend to spin out quite quickly. Especially if the bike in question has, (cough, cough) been deresticted. Anyone gone up to a 34 or even a 36 tooth , and if so how does it translate on the...
www.emtbforums.com
Chainring replacement how to .. - EMTB Forums
There's been a bit of discussions on the chainring sizes and replacements so I thought I'd document the procedure for the folks who are unsure what to do .. These are the bits that I bought, I stuck with Praxis having the Wave Tech, as the original chainring had this.. Praxis Works MTB Wave...
www.emtbforums.com
Kenevo max chainring - EMTB Forums
Hi all. Looking at my kenevo it looks fairly close with a 32 tooth chainring to the swingarm. I understand that a 34t will fit but my question is will a 36t fit? Cheers
www.emtbforums.com
104 BCD Chainrings
