2020 Kenevo Comp Setting Sag
Pritchi83
35
20
Dublin, Ireland
Hi Everyone
Just a quick question on setting the sag on the comp. I am finding it very difficult to move the adjuster ring on the shock when its one the bike. I took the shock off the bike, took it apart and made sure there was no muck or grit stopping the adjuster from moving.
I can move it ok when its off the bike as i can get my hand all the way round the adjuster. Once its back on the bike the frame on one side makes it very difficult. Its nearly impossible when you get further into the tension of the spring,
With it on the bike i have put it up on the stand to see if that helps but it didn't help. Is this something that i just need to take the shock out of the bike while i'm setting sag or has anyone found any useful little ways around it
Definitely one of the best bikes i have bought and i cant wait to get back out on it.
cozzy
792
855
Hampshire UK
Surely shouldn't be that tight to turn unless you are preloading the spring too much. Nip the spring up than another 3 turns max isn't it? Maybe you need a harder spring.
Ameiza
92
68
Norway
What Mcharza said. You set the sag with the correct spring, eg If too much sag, you need to move to next spring 500lb to 550lb etc
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,514
4,796
Helsinki, Finland
Hi Everyone
Beautiful bike you have (y)
crazyethnic
159
156
Australia Victoria
set the spring collar with the back wheel on the ground so there is no movement in the spring and when the back wheel is back on the ground, it should be spot on.
