Kenevo Gen1 Kenevo 2020 setting
nappa
Farningham, kent
Hi all,
Got a 2020 Kenevo and was wondering if there was a mathematical equation to set the bike up to act in the same way as manual bike.
So based on rider weight and the weight of the bike to come up with a setting?
Thanks Paul
Hi all,
Thanks Paul
The rider weight will not change .
I guess you are trying to match the effort of pedaling a 14 kg bike ? Maybe a 10 kg bike ?
Anyhow is hard to say , but people on the levo swear that 10 % assistance do the trick .
From my point of view if you want to pedal hard ... just turn the thing off
its not what im trying to achieve, I'm trying to match a mate on a normal bike, say he is 80kg and I'm 104kg if we was both on the same analogy bike with same fitness level, im going to be working harder up the hill fact.
So I just wanted to know if anyone had a mathematical equation.
Talked time ago ... impossible to achieve on fix assistance levels .
An assistance level that will put you on the same level of effort on an 20% uphill will clearly give you an advantage on flat .
The only way I believe you can achieve this is modifying the assistance dynamically depending on your heart rate ( like blevo does with specialized bikes )
