I also ordered the 2020 Turbo Levo Expert Carbon in Gloss Carbon/Gun Metal. The price is $8,225.00, with delivery "sometime in August". I can't stand any of the 2019 color options, so I ended up ordering the 2020. Almost went for the 2019 S-Works for an even $10k, but just couldn't quite justify the cost difference.
Here are the specs:
FRAME FACT 9m Carbon w/ M5 alloy rear triangle, 29 Trail Geometry, Integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge
bearings, 150mm of travel
FORK Fox 36 Performance, 150mm travel, Grip damper with 3 position micro adjust, 51mm offset
REAR SHOCK FOX FLOAT DPS Performance, 3-position adjustment, 52.5x210mm, Rx Trail Tune
FRONT HUB Specialized, sealed cartridge bearings, 15x110mm spacing, 28h
REAR HUB DT Swiss 360, 3-pawl design, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
SPOKES DT Swiss Competition Race
RIMS Roval Traverse 29, hookless alloy, 30mm width, hand-built, 2Bliss Ready
INNER TUBES Standard, Presta valve
FRONT TIRE Butcher, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
REAR TIRE Eliminator, BLCK DMND Casing, 2Bliss Ready, 29x2.3"
CRANKSET Praxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRINGS 32T, custom steel
SHIFT LEVERS SRAM S700, single-click lever
REAR DERAILLEUR SRAM X1, 11-speed
CASSETTE SRAM XG-1175, 11-speed, 10-42t
CHAIN KMC X11ET, 11-speed w/ Missing Link™
FRONT BRAKE SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKE SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
HANDLEBARS Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
GRIPS Specialized Sip grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEM Specialized Trail, forged alloy, 4-bolt, 5mm rise
SADDLE Body Geometry Myth 155 S, Body Geometry Henge 143 M/L/XL, hollow cr-mo rails
SEATPOST Command Post IRcc, 16-position micro-height adjustable, two-bolt head, bottom mount cable routing, remote SRL lever, 34.9mm, S: 130mm, M/L/XL: 160mm of travel
SEAT BINDER Specialized bolt-type, alloy, 38.6mm
SWAT Specialized Z-Cage, Swat CC Multitool in steerer tube without Chaintool
MOTOR Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/REMOTE Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®
BATTERY Specialized M2-700, integrated battery w/rock guard, 700Wh
CHARGER Custom charger, 42V4A w/ Rosenberger plug
WIRING HARNESS Custom Specialized wiring harness
PEDALS Specialized Dirt
