Chain stretch dilema.
Old Codger
South Yorkshire
I have three flat bar chain checkers which I use and change my chains at 0.5%. I recently purchased one of those with the small pins and sliding gauge and printed on it it said that new chains can be between 0.25 and 0.5%.
Thinking this was strange I checked three new Shimano chains, one 12 speed and two 11 speed with all four checkers and sure enough all three chains were at 0.25%.
Does this mean that I should be going up to 0.75% before changing chains? What do people think?
New chains are 0.00% - If your "checker" tells you something else it is not right for whatever reason.
Measuring roller centres is the only failsafe/accurate way to do it IMO.
I now use one of these stupidly priced, but deadly accurate devices....
I always measure a new chain over 100 links, ie 50 inches. Then if it is different, (it never is) I can compare later.
Years ago, I used to measure with an internal vernier caliper gauge. The distance I measured was 5.7". A new chain was always 5.700". But when I started using 11 and 12 speed chains, the start measurement started to vary. (I suspect that the rollers were a different diameter to previous). Initially, if I recorded say 5.706" then that was the measurement I used to compare the same chain as it wore. But then I noticed that despite very careful measurement, often repeating the same measurent several times to ensure that I was as accurate as possible, the chain would vary along its length. What! :unsure: Yes, using a vernier caliper, the chain would vary along its length, implying differential wear. It didn't matter how many times I measured the same section of chain I always got the same result, so at least I was consistent. Move the crank half a turn and measure again, different! This should be impossible as it cannot be manufacturing variation within the length of a single chain. I know how chains are made and it is unlikely to the Nth degree. Maybe the rollers are barrel-shaped, or maybe they do wear differentially? :unsure:
So I stopped using my vernier caliper (more accurate than a go/no-go chain gauge.) Instead I started removing the chain and measuring across 100 links. This method averages out any section-to-section wear and reduces the error impact of any measuring-device-to-chain-contact variation by nearly nine fold.
What this says to me is that the short distance over which chain gauges operate cause them to be inheritantly inaccurate and can cause a chain to be retired long before it is necessary.
So if you have a chain that is due to be replaced according to your chain gauage, check the chain over 100 links and then make your decision. Measure with a metal tape measure, with the chain laid flat over a flat surface and pulled tight.
50" = new chain
50-1/8" = 0.25% = OK
50-1/4" = 0.5% = OK (As far as I'm concerned, but I'd buy a replacement ready for action. As long as the chain is running OK).
50-3/8" = 0.75% = replacement asap.
But you don't have to measure to the nearest one eighth of an inch. Most metal tape meaures have increments of 1/16". That is to 0.125%. That is more than accurate enough, but if you are careful, it is quite easy to meaure to 1/32" i(0.06%)! The choice is yours. :)
50" = new chain
I check a new chain (usually Shimano CN-9100) with a Park Tool CC-2 in several places then change the chain when it stretches more than 0.5% from that baseline (normally measures 0.0 when new). Simples.
It'swe not uncommon for new chains to register more than 0.0% wear, up to 0.25%... depends on the checker. No, you should replace at 0.5%, regardless of starting point.
Some checkers only measure a short distance (4-6 inches), so ERROR is greatly magnified.
I'm not sure if you have ever checked out all of the chain wear testing, and chain lube testing (vis a vie wear prevention) on the ZeroFrictionCycling site, but if you haven't done so, it is well worth a read and really allows one to geek out on the tech nuances of this stuff.
Since wear testing is such a big part of his chain and lube testing, he has also done a deep dive into how best to actually measure wear, and has written extensively on the topic. Interestingly, he has found that many wear gauges are inaccurate out of the box, or for ones that require the user to apply some degree of pressure "by feel" to the tool to gain the reading, introduce a substantial amount of inaccuracy based on how hard the user is pressing. I had always thought that @steve_sordy 's method of measuring the whole chain made the most sense, as the stack up of wear along the whole length of chain would make wear easier to determine, as the total number of millimeters of wear will be greater on a full chain than the 100-150mm that most checkers measure. Interestingly, according to the ZeroFrictionCycling guy, that is not the best method, because a given chain will not wear totally evenly along it's whole length, and the most worn sections will be the sections that cause wear to the teeth on your cogs. In other words, you may throw the gauge on the chain and get a reading of 0.4%, leading one to think you can run it a bit longer, but another section of that same chain may be past the limit at 0.6%. He suggests using an accurate tool, and measuring 3-5 separate sections of the chain, using the worst reading to determine if the chain should be replaced.
Here is a link to a whitepaper he published testing the accuracy of different chain gauges against a known 0.5% worn chain: https://zerofrictioncycling.com.au/wp-content/uploads/2024/03/Chain-Wear-Checkers-Table.pdf
He has also written extensively about the effect of Sram's oversize rollers on some of their chains messing with gauge accuracy, and also about the differential rate of roller wear (which doesn't actually lead to "stretch"), and pin/plate wear (which does lead to chain "stretch"). Many tools include roller wear in their measurement, so if you have a chain model with very hard wearing pins and plates, but relatively soft fast wearing rollers, then you will get a measurement on your gauge that indicates it needs to be replaced, even though the actual pin-to-pin distance is still well within the acceptable range. He also emphasizes the need to measure a chain that is relatively clean, but not freshly wax lubed, because both grit and a fresh coat of wax will take up some of the extra space in the pin/link interface, leading to the appearance of a chain that measures out as less worn than it truly is.
Anyway, hopefully that is of interest and not TMI.:LOL:
Why on earth is the SRAM flat top chain checker so expensive?
£30 for a little sliver of metal seems a bit much.
Anybody seen them cheaper?
As said in post #4
@TheKaiser At last it was not a figment of my imagination! Somebody else agrees with me that chain can wear diferentially olong its length!
"....Interestingly, according to the ZeroFrictionCycling guy, that is not the best method, because a given chain will not wear totally evenly along it's whole length, and the most worn sections will be the sections that cause wear to the teeth on your cogs. In other words, you may throw the gauge on the chain and get a reading of 0.4%, leading one to think you can run it a bit longer, but another section of that same chain may be past the limit at 0.6%. He suggests using an accurate tool, and measuring 3-5 separate sections of the chain, using the worst reading to determine if the chain should be replaced....."
When I first noticed it, I started to measure every half turn of the crank until I'd done the whole chain and then averaged them out. At first I could not believe it and I assumed that it was my measurement technique at fault. But I got the same result each time I measured the same section of chain. I have no explanation for this variation. It is why I prefer to remove the chain and measure over 100 links. If I am going to average the chain, why not do it properly and much more quickly?
Whilst I noticed it, I have no idea why it happens. Chains are assembled from randomly mixed parts on a machine. Unless you have seen how chains are made you cannot imagine just how randomly they are mixed. (I did 6 weeks in a chain factory as part of my engineering training). The machine could vary of course, but it would have to be drifting in and out of the standard settings on a very rapid basis. When the chains wear differentially, it can be produce different measurements within half a crank, lets say 17 teeth, or 8.5". Not feasible.
Just had a thought! Maybe chainwear is a bit like braking bumps. One person creates a slight skid, the next person digs out a little bit more. Soon every body's wheels are digging in the same hole, and the hole gets deeper rapidly. If you stamp on the pedals, or do something that causes a little bit of wear on a tooth or on rthe pins of a few links, then maybe they attract further wear later and it accelerates! Just a thought, not a well thought through theory. Can anyone else come up with a proposal, or do they actually KNOW?
Wow, that is cool you worked in a chain factory! Whenever I've seen a video of those production lines, it really boggles the mind how they assemble all those little pieces so quickly and precisely. Yeah, the differential wear within 1 chain seemed unintuitive to me too, but your theory is the best I've heard yet. Bearing races can work like that, if memory serves, where if one bit takes a hard impact and gets a little dent, or there is some brinneling or corrosion, then future wear under normal use can magnify and expand the damage to the bad spot, or cause increased wear on the mating bearing surface due to the irregular loading.
Another thing that occurred to me is that a lot of these chains have various surface treatments, both of the friction reducing and the hardness increasing variety, so if one section has the coating wear through or crack or corrode off, then that section will be unprotected and more subject to future wear, again, causing the differential to the uncompromised section of chain to increase at an even faster rate.
Edit: This thread just prompted me to review the old info and check out what is new on the ZeroFrictionCycling site, and I found this passage in his write-up on the Shimano chain wear gauge (which is one of the few that attempts to separate roller wear from pin/plate wear). It ties into this topic of non-linear wear rates based on on the various coating layers: "Chain wear rates are NOT LINEAR. Initially a quality chain will have wear protective treatments such as a low friction coating and one version or another of chromium plating on some components. As these coatings / plating’s become compromised from wear, AND typically the amount of abrasive contamination deep inside chain builds over time, people get caught out doing a check at “X” kms to find chain wear is minimal, and then again at same km’s later to find chain has ripped past recommended replacement mark." It makes sense to me that the coating thicknesses won't be perfectly even across the whole length of chain, so that seems like the most likely culprit in differential wear rates. As a result, you might get a situation where they chain wears more or less evenly across it's length up to a certain point, but then the sections where the protective coatings are thinnest wear through, and suddenly those areas "stretch" at an accelerated rate.
That is a treally great find! It sounds right.
@irie I agree with your statement "No component comprised of over 100 supposedly identical components will perform with perfect homogeneity." However, I was not assuming that all the sideplates are identical to each other, nor the inner plates identical, nor the pins and not the rollers either. What I was assuming was that any manufacturing variations in the millions of components are averaged out by the assembly process. They churn these items out by the million and they all end up in hoppers where they are randomly mixed and then dropped into other hoppers that feed into active and passive devices that automatically orientate the items for assembly. The random mixing is not deliberate, just a function of the process. But if it didn't happen that way, they would have to find a way to do it deliberately.
Because the product is produced from randomly sorted components, I made the (safe) assumption that the end product shows almost zero variation. From that I made the (dodgy) assumption that it would wear in a uniform manner. I struggled to think of a mechanism to generate random wear along a 120 link length of chain. But this thread encouraged me to think again and I came up with the braking bump analogy. That in turn prompted @TheKaiser to search the ZeroFrictionCycling website and find an explanation that has the ring of truth about it.
It was during the Summer of 1976 in the the UK. It was the record breaking heatwave, so it definitely was not cool! I was part way through a four-year sandwich course in mechanical engineering (three years of six months at University, followed by six months in industry, then one last year all at Uni). My industrial sponsor was a manufacturer of mechanical power transmission of all kinds (gearboxes, clutches, couplings and much, much more). They were owned by Renold Ltd, at the time the largest manufacturer of chain in the world. I saw a triple stand of 7" pitch chain being made for a merchant ship engine, but they had made bigger in the recent past. I still have a couple of inner links of 2" pitch in my posession somewhere in the house. You sure would not want to drop one of those on your foot! The presses that stamped those out were huge!! The bigger the link, the fewer they stamped out at a time. They also had rows of women assembling low quantities of specialist small pitch chains. Men were just not fast enough to earn bonus money. I also remember that they made a "pusher chain". It looked remarkably like Sram's T-Type transmission chain, only much bigger. They were used to push torpedos into their tubes, yet coil up into a small space when not being used. Better than a hydraulic ram when space is at a premium!
Omitted to say that dirt and other surface debris will not be evenly distributed on the chain thus chain wear will not be even.
Sorry for the late reply, been away.
So, I got a 1 inch batten of wood with a pin in one end to fit the end chain link (tight fit). The batten was marked off at exactly 50 inches (100 links).
The actual measurement over 100 links was +3/32”, so that’s 0.18%. I did put tension on the chain.
I then measured at several places with two flat chain checkers and a Park Tools CC-2 vernier type and they all gave 0.75%.
I can only assume that the wear must be on the outer rollers circumference and not the link pins. So, do I change the chain?
The pitch has hardly changed , so the rollers will be settling nicely into the root of the teeth instead of sliding up and down looking for a low energy position (and wearing the face of the teeth). So it looks OK, But there are other things to consider because you don't want to economise on an old chain and mess up the rest of the transmission.
How many miles has the chain done?
Does the chain look tired? Rust patches, stains that don't clean off etc.
How is the sideflex? See the following thread, post no #19
Let's start with: chains don't *stretch*. They wear. Which lengthens them.
I still just use a 12" steel ruler and 0.5% is almost exactly 1/16". I measure 12" worth of links with the chain straight and see if there's more than 1/16" over.
Chain has done 1300mls but I have changed it as I have done for years when the the gauges register 0.5%. But by the 100 link method it looks ok so the dilema is which do you trust.
My chains are always clean and looked after and for what they cost I don’t mind replacing them. This is the first 12 speed I’ve had and it
@Old Codger 1300 miles is good for an emtb chain. Correction! It's VERY good!
You have had your money's worth out of it; so change it, the rest of your transmission will thank you. :)
I have had a chain that had similar results to you. But I could tell it was not right by the rumbling noise I was getting. I did a sideflex test and that convinced me to ditch it.
    Join 43,069
