I always measure a new chain over 100 links, ie 50 inches. Then if it is different, (it never is) I can compare later.
Years ago, I used to measure with an internal vernier caliper gauge. The distance I measured was 5.7". A new chain was always 5.700". But when I started using 11 and 12 speed chains, the start measurement started to vary. (I suspect that the rollers were a different diameter to previous). Initially, if I recorded say 5.706" then that was the measurement I used to compare the same chain as it wore. But then I noticed that despite very careful measurement, often repeating the same measurent several times to ensure that I was as accurate as possible, the chain would vary along its length. What!
Yes, using a vernier caliper, the chain would vary along its length, implying differential wear. It didn't matter how many times I measured the same section of chain I always got the same result, so at least I was consistent. Move the crank half a turn and measure again, different! This should be impossible as it cannot be manufacturing variation within the length of a single chain. I know how chains are made and it is unlikely to the Nth degree. Maybe the rollers are barrel-shaped, or maybe they do wear differentially?
So I stopped using my vernier caliper (more accurate than a go/no-go chain gauge.) Instead I started removing the chain and measuring across 100 links. This method averages out any section-to-section wear and reduces the error impact of any measuring-device-to-chain-contact variation by nearly nine fold.
What this says to me is that the short distance over which chain gauges operate cause them to be inheritantly inaccurate and can cause a chain to be retired long before it is necessary.
So if you have a chain that is due to be replaced according to your chain gauage, check the chain over 100 links and then make your decision. Measure with a metal tape measure, with the chain laid flat over a flat surface and pulled tight.
50" = new chain
50-1/8" = 0.25% = OK
50-1/4" = 0.5% = OK (As far as I'm concerned, but I'd buy a replacement ready for action. As long as the chain is running OK).
50-3/8" = 0.75% = replacement asap.
But you don't have to measure to the nearest one eighth of an inch. Most metal tape meaures have increments of 1/16". That is to 0.125%. That is more than accurate enough, but if you are careful, it is quite easy to meaure to 1/32" i(0.06%)! The choice is yours.
