Seems 55mm. Could be 56mm.Can you measure how far out the center of your chainring is from the middle of the motor? Mine is 55mm exactly![]()
Darren at drip said his shipment has arrived at the port so shouldn't be too much longer.
Thanks, yes l am keen to hear back on the PB full review with Flux done a while back.... have you achieved towards a smooth chain line from HP cog corresponding above chain ring.Looks good! Nice to see people slowly getting them![]()
My Flux has perfect chainline, and the chain runs super smooth. Since changing the bent cage, the shifting is so quiet and smooth. And as you say. The motor is super quiet. Much quieter than my Amflow.Hey team,
Hows all your FLux going? We need some more pics!
Negative on the chainline misalignment, still out 2-3mm and I don’t think there is anything I can do about it. I have an inquiry in with the Aussie Teewing brand manager so will see what he comes back with.
In other news the chain dropped of the idler today and jammed itself up pretty good. Had to break the chain to get it out. I’ll check my chain length tomorrow, I am running a very well used 11 speed sram unit, maybe the clutch is worn out and let the chain get outta control, still, never dropped a chain on the Spesh Enduro it was installed on before.
Love the bike, it rips, coil shock feels way better then the air, but I’ll have a tinker with the air to see if I can close the gap.
I can’t believe how quiet the motor is, was riding with a mate on a Levo 4 and I could hear his motor as we rode next to each other but not mine.
1. Chain fell outboard
- Did the chain fall to the inboard or outboard side of the idler?
- If the gap between the idler and surrounding chainstay is unequal on each side, did it fall to the side with the bigger gap or the smaller one (I looked at your pics in an earlier post and it looked like the gap was bigger on the outboard side, but it was tough to tell)?
- If I understand the problem correctly, the chainring sits a few MM inboard of the idler (i.e. the chainring has a 55mm chainline, but the idler is more like 57mm+), correct?
If the chain indeed fell inboard, as if it was seeking alignment with the chainring, then, if it were my bike, I'd probably pick up an inexpensive chainring to use on the stock spider, with spacers to get it lined up with the idler, at least until an official solution comes from Teewing.
If the chain fell outboard, and there is indeed a bigger gap between the stay and idler on that side, I'd consider adding some material to supplement the built in rubber frame protection and act as a more comprehensive chain guide to keep it tracking straight onto the idler.
That is very charitable of you to consider that your clutch might be to blame, and more tension is generally better when it comes to keeping chains from derailing, but it seems unlikely to me that it is the root cause. Any slack on the bottom run of chain would need to be translated around either the chainring or cassette in order to generate excess slack at the idler. If the chain fell of the bottom section of the chainring, then then I'd certainly consider the clutch as a potential culprit.
On technical terrain. The Flux is second to none. But on trail rides like riding the Centenary Trail. At 20kgs, the lightness of the Amflow is just a bit better. But there's not much in it. Where as on downhill technical, the Flux is just so far ahead of the Amflow.Teething issues aside, just want to iterate how awesome this bike is.
Did you (or anyone else ordering from Drip like @Lawndart ), ever get your bikes? Given how many people on the thread mentioned placing orders, I've been a little puzzled by the lack of enthusiastic "unboxing" posts and 1st ride reports? I see now Drip is talking about August deliveries, but wasn't sure if that was just for new orders, or if they've pushed back the OGs like yourself to August too.Mine is supposed to be here this month. This month is quickly coming to an end. Communication hasn't been the greatest from them, but I'm keeping my hopes up. I sent a text and got no response, sent another text and got this response.
Hey Bryan - Sorry for the slow response. We've got some progress and setbacks at the same time. I should have some answers in the morning. We're getting frames air shipped now as well because of delays. Will reach out tomorrow.
That was on the 19th and I never got another text. Now that the remembrance weekend is over, I'll reach out again this week.
Realistically, I'm not sure how many different manufactures are delivering on bikes right now. So, even if I wanted to go a different route, it's going to be hard to get something as well equipped for the same amount of money.
I ended up cancelling my order and going a different route. Drip E-Bikes refunded all my money except for $150. Wrote that off as a processing fee. I’ve since bought a Levo 4 Expert through Specialized’s Veteran program, took delivery 5 days after I ordered it and have put in 2-3 rides a week since.Did you (or anyone else ordering from Drip like @Lawndart ), ever get your bikes? Given how many people on the thread mentioned placing orders, I've been a little puzzled by the lack of enthusiastic "unboxing" posts and 1st ride reports? I see now Drip is talking about August deliveries, but wasn't sure if that was just for new orders, or if they've pushed back the OGs like yourself to August too.
For Your Information B,FYI;
Beautiful thanks B Rabbit l will go do this.... l have downloaded the latest updates.The motor is easy to pull out, 2 bolts, yep, you can leave the cranks and pedals on.
Have you don’t the latest software updates?
Might be worth doing that before pulling stuff out.
Nice looking bike Marty. Love it.Beautiful thanks B Rabbit l will go do this.... l have downloaded the latest updates.
The same happened to me twice now. Really enjoying. SRAM GX T type drive train1. Chain fell outboard
2. From memory the gap is fairly equal
3. Yes, Idler sits outside the chainring by a few mm, maybe 3.
Yes, I was very surprised to see the chain come off the idler, it just looks super secure. I dont suspect the idler being slightly off the 55mm chainline would effect holding the chain or not as the chain cross coming from either the low or high gear on the cassette would dwarf that.
And re suggesting the derailluer could of played a part, just want to be as charitable as possible as this could of just been a random one off event and until/if other people start having the same problem it could definitely be some sort of setup issue on my end.
A quick search of FB does show someone having a problem dropping the chain off the idler, according to the OP Teewing sent out a different "high pivot screw" (might be a slight translation problem there).
I will report back if the problem persists
Teewing (DJI Avinox) Owners Club - TWOC | I bought this bike, but the chain has come off multiple times while I've ridden it | Facebook
I bought this bike, but the chain has come off multiple times while I've ridden it. I've reported it to T-Wing and they've provided a solution, but the problem persists. Have any of you experienced this?www.facebook.com
Teething issues aside, just want to iterate how awesome this bike is. Apart from a bit more adjustment in the chainstay department I dont think there is a thing id change on it. It rips! (both up and down)
So is this also a frame build ? I make this assumption as the GX T-type doesn't come standard on the factory built bikes. The facebook guy also had an older non-factory SRAM transmission, so probably a frame build as well.The same happened to me twice now. Really enjoying. SRAM GX T type drive train
Thank you Astro66..... the error to the sensor has been restored, possibly the plug wasn't completely clipped fully.Nice looking bike Marty. Love it.
I'm sorry to hear you guys are having a few teething issues. Kind of glad I didn't get a frame. Buying the completed bike and just changing a few parts, my bike has been flawless. Sorry if that sounds smug. It's not meant to be. I'm just trying to say the factory assembled bike has been trouble free.
I did pull the motor out to install the derailleur power cable. Very simple process. You do need to work out if its a cable connection, or sensor pickup issue.
I did replace the rear wheel, but re-installed the same disc rotor and speed ring. And there has been no issues. It came with SRAM Centreline rotors, which I also just happen to fit to the Amflow. Replacing the Magura rotors.
But I did not touch the original wheel or hub. I even left the original tyre and tube in it, so if there was any issue, I could refit the original wheel and compare.
Hope you sort it out mate.![]()
Glad you got it sorted mate. Look forward to more pics of you launching it off those jumps. This is me launching mine ......Thank you Astro66..... the error to the sensor has been restored, possibly the plug wasn't completely clipped fully.
Happy days out on the trails, composed, focussing up ahead, Flux and confident on board, all systems go, loving it!Glad you got it sorted mate. Look forward to more pics of you launching it off those jumps. This is me launching mine ......
This is the big one I noticed. So quiet. The other big one is the squish when landing jumps, rather than a bang. It's like landing on a pillow. It gives you confidence to go a little quicker, and then I don't end up casing any jumps. Especially the smaller gap jumps, which I'm now finding the confidence to just send them.This bike is so very quiet,
Least i'm not aloneThe same happened to me twice now. Really enjoying. SRAM GX T type drive train
