Poor man's CEF69 M510 FC4.0 with 1kWh battery
fork 170 travel, 205x65 rear shock, 29"x 2.6/2.5 and only 337 mm between crankcase arms axel and ground ? it's the first rev linkage or the later adapted for X2 shock ?
Yes, only 337 from the ground to the motor axle.
I think this is the first iteration of the linkage. I got the frame around September 2025.
Cheers
Cheers
ok. thanks. like the CEF50, i will can't use it in mullet
Cheers
other customer measure different value: ? 355 with 29/170/205 ?
Hi. Did you build the battery in a 3D-printed enclosure or use a different approach? Can you share some photos and instructions?
There is no 3D print for the battery.
I used 3x1 2170 cell holders formed in 3x3 factor. All sandwiched in between 3mm fiberglass,top and bottom. And for the mount I used 5x25mm aluminium bar with floating threaded inserts. Aluminium bar was offseted to make a room for brake and shift cables on the left side of the battery.
hi. will these holders be ok? for 21700. they fit in the frame
    678K
