Thanks for posting,Looks like the latest roundup is up now for 2026: The Best E-Mountain Bike of 2026: 30 eMTBs in Direct Comparisons in Our Huge Group Test. Quite an exhaustive test programme.
My sons has the composite version and they are very good.Anyone thoughts on Burgtec Penthouse Flat MK5:
https://burgtec.co.uk/product/penthouse-flat-mk5-pedals/?v=c0d4b2f1d3e1
Same allow as the bike 7075, machined, steel axle or whatever (the middle bit the pedal spins around I dunno the term?) and a nice raw finish to match the rest of the bike?
One of the best flats about imo. Nice and grippy, super strong and fairly thin to help with ground clearanceAnyone thoughts on Burgtec Penthouse Flat MK5:
A glued together frame,yuk,looks very 90,sThe other thread seems totally convoluted and presently full of none relevant conversation.
Original thread : Atherton Dyf-E bike coming soon...
Therefore, here's a thread relevant to the actual bike.
Tidied up image from @GatorXman
Launches April 2026. Pre-orders are open now for the first 50 bikes (Total £8999 - S.170E.1 / S.170E-2 - £7799 / £6999 - S.170E.3), with delivery scheduled for April and May. (Deposit £1000, Balance due 30/03/26) - Example Pre order S.170E.1 bike : Fox Factory suspension and SRAM X0 Eagle Transmission
Atherton bikes direct link :
S.170E.1
Full-power Avinox drive. Fox Factory suspension. A bonded 7075 aluminium chassis built for big mountain riding and self-shuttling your favourite enduro tracks.Our EMTB's are only available to UK and European customers. We plan to expand distribution in 2027...www.athertonbikes.com
Basic Specs :
Avinox drive unit
Full-sized battery inside downtube
DW4 suspension with 170mm rear wheel travel, 180mm fork, and MX wheels
63.6° head angle, 75.6-77.6° seat angle, 435-445mm chainstays
Machined lugs and 7075 alloy tubes
12 sizes, 405-515 mm reach
Mavic E Deemax mullet wheels, Hayes Dominion A4 brakes, and FSA Gradient cockpit
All sizes will have the same size battery - battery size yet to be confirmed.
Geo :
Looks like it’s worth the wait then
They have resolved the head tube entry ports so we can run with left hand rear brake. CoolBike is here and together, I'm away for the weekend so first ride will have to wait ,View attachment 186518
Thought they all came with conti tyres. Did you swap them?Bike is here and together, I'm away for the weekend so first ride will have to wait ,View attachment 186518
Yeah it's much betterThey have resolved the head tube entry ports so we can run with left hand rear brake. Cool![]()
Yeah it's the spare wheel set for my other bike.Thought they all came with conti tyres. Did you swap them?
Congratulations! I'd have mine in the house till the first ride so I could amireBike is here and together, I'm away for the weekend so first ride will have to wait ,View attachment 186518
The main climb to the top of Hawes trail system here in Arizona is also named Alpe d'Huez!First ride out on the bike was great. I've been worried it was just to much bike but that doesn't seem to be the case at all. Very easy to manoeuvre and jump around on the trail. I didn't go mad, I deliberately went out with a bag full of tools and forgot my pads.
Setup the suspension to the recommended settings and changed auto to 3 to 11 after watching a couple of videos. Everything else as it was..
I think I normally ride a bit over the front fork but found I don't need to put as much weight on the front of this bike.
I dropped about 10 psi out of the fork (137 down to 127) and reduced lsc 2 clicks, added 5psi to the shock upto 230 , rolled the bars fwd a tiny bit then it felt really balanced. I'm about 83kg for info and this is a size 8. Rebound on the shock is just a bit too quick so I'll be adjusting that but the trailhead rockshox app seems pretty accurate.
The motor is pretty much ridiculous in that auto mode. The 12 mile loop took me under an hour, I'm sure it's normally 1.5 to 2 hrs
I set Strava to public briefly, think I had a KOM, several top 5s and that was just auto, I did drop it into turbo on one of the road climbs we call alp d'huez and it was bouncing off the speed limiter.
Even the saddle seemed pretty comfy despite not looking it to me
Anyway extremely happy overall. It did flash up a motor power restricted warning after about 20 mins, on off cleared it and didn't come back so I'll keep an eye on that.
View attachment 186795View attachment 186796
With regards to Motor Power warning, I had this on my Pro go into advanced settings and turn off the “ extreme elevation setting” Basically if it detects the bike angle is to steep itFirst ride out on the bike was great. I've been worried it was just to much bike but that doesn't seem to be the case at all. Very easy to manoeuvre and jump around on the trail. I didn't go mad, I deliberately went out with a bag full of tools and forgot my pads.
my pro did the same. You can go into the advanced settings and switch off the elevation mode. This fixed the issue. Hope this helpsFirst ride out on the bike was great. I've been worried it was just to much bike but that doesn't seem to be the case at all. Very easy to manoeuvre and jump around on the trail. I didn't go mad, I deliberately went out with a bag full of tools and forgot my pads.
Thank you for taking the time to write this up! How was battery consumption?First ride out on the bike was great. I've been worried it was just to much bike but that doesn't seem to be the case at all. Very easy to manoeuvre and jump around on the trail. I didn't go mad, I deliberately went out with a bag full of tools and forgot my pads.
Sorry I should have said, that was 38% usedThank you for taking the time to write this up! How was battery consumption?
Would have been nice, always next time though.Was hoping to take mine to the Alps end of next week but just had a message saying it will be ready on 3rd July so just too late![]()
Unlucky man. Have a nice time anyway. Some of us are stuck in the UK (a flat bit).Was hoping to take mine to the Alps end of next week but just had a message saying it will be ready on 3rd July so just too late![]()
Am batch 2 #75. Was told built 18th June for collection the week after so not delayed by too much, just enough!!Would have been nice, always next time though.
What batch was your order in?
I’m in batch 3, I was previously told mid July - although I still haven’t received any specific ETA yet (likely going to be delayed also).
Cheers
Was hoping it would be ready based on the date given a month ago.Unlucky man. Have a nice time anyway. Some of us are stuck in the UK (a flat bit).
Mine is batch 2 #75 and I am collecting it week today.Looks like my July 8th date delivery date will be missed - expect to get a firm date next week. Anyone else picked up theirs from this batch (think its batch 3)?
I'm in batch 3, I still haven't gotten a fixed ETA.Looks like my July 8th date delivery date will be missed - expect to get a firm date next week. Anyone else picked up theirs from this batch (think its batch 3)?
I was miffed when mine slipped a week. Currently in the Swiss Alps on my Decoy. Picking the new bike up on my way home.I'm in batch 3, I still haven't gotten a fixed ETA.
First it was mid July, now it's approx end of July / August - but they still cannot commit to a date yet... Busting to have it for the summer![]()
I'm considering fitting a EXT, but I'll ride it as is first then decide.Anyone fitted a coil to theirs yet?
Have a Telum coil to go on mine.Anyone fitted a coil to theirs yet?
