Specialized Levo Gen 3 motor error and no pedal assist after climb — fixable?
devinkalt
I'm on a levo gen 3.
4275 miles on bike, turbo mode on a climb the motor made some weird sounds. pedal assist cut out, motor error message. now the pedal assist doesn't apply power to chainring. motor will sound like it's working while pedaling but sounds different now and it doesn't provide any pedal assist. can still ride bike like normal without the motor on.
@Greg Watts
That sounds like the motor's spun a sprag clutch — or worse — and the symptoms you're describing are pretty textbook for it. Let me lay out what's going on.
Your Gen 3 runs the Specialized 2.2 (Brose Drive S Mag-based, 90Nm, belt drive with dual sprag clutches). The key tell in your description:
Motor "sounds like it's working" but no power reaches the chainring. That's the giveaway. The motor is spinning internally but the drive isn't being transmitted to the spindle. On a Brose/Specialized 2.2 that points to a failed sprag clutch or stripped drive belt inside the unit. The weird noise on the climb under load in Turbo (peak ~565W mfr-claimed, measured higher), then the cut-out and error, fits something letting go mechanically rather than a sensor glitch or wiring fault.
A few things worth ruling out first, in order:
Read the actual error code. Plug into Mission Control (or have the dealer pull it via the Specialized diagnostic tool). A specific code narrows internal-mechanical vs electrical fast.
Check it's not a cable/connector issue. On here, @Just gan and others have flagged that on earlier Levos a cracked or damp battery-to-motor cable can cause non-start and dropout behaviour, often a day or two after washing. Worth eliminating — but a damp cable usually kills the motor entirely, it doesn't let it spin-without-drive. Your symptom leans mechanical.
Don't keep riding it under power. If a sprag or belt has gone, hammering Turbo into it can turn a clutch swap into a full motor replacement. Riding home unassisted (as you've been doing) is fine — the motor freewheels.
The realistic outcome: this is almost certainly a warranty motor replacement. The good news is Specialized's track record on motor swaps is solid — on this forum the consistent owner experience is that 2.x motor failures get replaced under warranty without much fuss, and at 4,275 miles you're well within a normal lifespan for a claim. Specialized's standard motor warranty is 2 years, so if the bike's within that window from purchase you should be covered. Get it booked with the dealer with the error code in hand.
For context, plenty of Gen 3 owners are well past 7,000 miles with zero motor issues — so this is a known failure mode, not the typical experience. You got unlucky.
What's the exact error code showing, and roughly how old is the bike from purchase? That'll tell us if it's a clean warranty job.
I opened the motor and the belt is still in tact however i noticed it looks like the belt was rubbing the inside of the cover i removed and it had been rubbing / shearing / polishing the inside of the motor cover. so i guess that means it's the sprag clutch, right? bike is over 2 years old, out of warranty.
I opened the motor and the belt is still in tact however i noticed it looks like the belt was rubbing the inside of the cover i removed and it had been rubbing / shearing / polishing the inside of the motor cover. so i guess that means it's the sprag clutch, right? bike is over 2 years old, out of w...
@devinkalt Good sleuthing opening it up - and yes, that belt-rubbing-on-the-cover detail is useful information.
The belt being intact actually narrows it down nicely. The Brose S Mag runs dual sprag clutches in series with the belt drive, so you can have a failed sprag with the belt still perfectly healthy. The sound you're describing - motor spinning, no drive transmitted - fits a sprag clutch that's freewheeling in both directions rather than locking up to transfer torque. The belt contact mark on the cover suggests something shifted slightly internally, possibly consistent with a sprag collar moving out of position under load.
@oripaamoni described near-identical symptoms on a 2019 Levo years back - motor spinning up to max RPM, very little or no actual assist - which turned out to be a motor replacement job: @oripaamoni's post
On warranty: out of the standard 2-year window is the bad news. Worth one conversation with your dealer anyway - if the failure mode is something Specialized have acknowledged internally, goodwill replacements do happen, especially if you can show it's clearly a mechanical failure rather than crash damage or abuse. Worth asking the question with zero expectation, basically.
If goodwill's a dead end, you're looking at either a replacement motor unit or a third-party Brose S Mag rebuild specialist. A full Specialized motor swap out of warranty isn't cheap - budget £1,000 - £1,500 fitted, possibly more depending on your dealer. Some riders have found independent Brose service centres a more economical route.
What error code did Mission Control show when it cut out?
A good dealer can offer you a new motor at trade price then you get 2 year warranty. Most I have had is 3300 miles out of any of mine. Gen 3 one went a month ago 2200 a year old .It was making a scraping noise occasionally before it went. Good luck.
I am looking at sending it in for a repair to a shop in Tennessee. (I’m in Arizona , USA) how much does a new motor at trade price cost? USD$
It was £600 last February when I was thinking about it. A upgraded reconditioned one was £500 . Gen 2 levo the Motor was ok but had 3000 miles on it . It was my forth motor so I sold bike and got a gen 3 I wish I had changed brands as the first one on this bike went a month ago.
    676K
