Look up how condensation forms. On our bikes it is not just a motor issue.....condensation also occurs inside the bike frame.......one reason I am not a big fan of top tube mounted controllersThe motor failure in a wet climate is 10 fold to the failures in a dry climate. Its suspected that the motor casing expands with heat and when water is present, it gets drawn in to the casing ? Is that your opinion
Maybe you dont! The battery and motor create heat in use. That warms the air within the motor casing and bike frame. Warm air carries more moisture. If/when that warm air cools to the dew point it deposits water droplets on thd nearest hard surface. So spraying the bike with cold water will cause condensation. That is something to be aware of in both hot and temperate climates.I know how condensation forms, would it be more wet from rain or puddles for motor ingress. As for controllers, yet again, it seems a wet climate issue rather that just washing the bike.
Do you maintain the motors. Open them up and service them?none! I maintain all my bikes....that includes a thorough check on any new bike of assembly and potential issues....and I fix them before they cause issues. . Since 2019 I have bought 2 Specialized bikes ( one was stolen!) and 3 Whyte bikes.
Nope. If you have ever cleaned and regreased the motor seals around the BB crank drive you will see that the seals are very open to water ingress. Poor design to keep the price down.The motor failure in a wet climate is 10 fold to the failures in a dry climate. Its suspected that the motor casing expands with heat and when water is present, it gets drawn in to the casing ? Is that your opinion ?
No , if I thought it was needed I would send it to the ebike motor centre. My mate did that recently wjth his gen 2 Levo motor..... not because of any problem but as a precaution since it had done 4k miles. Cost no more than a short service on my BMW.Do you maintain the motors. Open them up and service them?
Zero, I have never needed to clean around the crank seals.Nope. If you have ever cleaned and regreased the motor seals around the BB crank drive you will see that the seals are very open to water ingress. Poor design to keep the price down.
Early adopters are always beta triallists. Add to that a product from a previously unknown brand and you are likely to pay the price.Avinox Failure Videos - Avinox – Google Drive
Simple suggestion.
If the majority of e-bikes are reliable, extend the warranty from 2 years to a realistic lifecycle of the frame, such as 5 years.
Having 2 motors fail with little use, one without even being turned on - my faith in Avinox is lost.
It is not about price....it is about keeping friction to a minimum. The ebike centre has a solution however. One issue with motors is that the bike brands do not deal with repairs....the failed motor is kept sealed and returned to the motor supplier. They probably just scrap it.Nope. If you have ever cleaned and regreased the motor seals around the BB crank drive you will see that the seals are very open to water ingress. Poor design to keep the price down.
DJI isn’t an unknown brand. They make motors for all sorts of products in a variety of different sectors.Early adopters are always beta triallists. Add to that a product from a previously unknown brand and you are likely to pay the price.
DJI is the parent company not the brand. Amflow is the brand. DJI developed the Avinox motor and system. Their electronics experience is in drones and cameras neither of which are anywhere close to the stresses and environment an emtb experiences. No bike, mtb, emtb experience in DJI or Amflow. Just access to low cost electronic components and labour and no doubt additional financial support from CCP to help disrupt another Western industry sector.DJI isn’t an unknown brand. They make motors for all sorts of products in a variety of different sectors.
Quality Control is clearly the issue here, whether it’s a bad batch of bearings or something else, who knows. The M2s has documented same issues so how early is too early to adopt a new system?
Yes, DJI is the parent company. It’s probably split for corp structure and tax purposes, such as the recent tariff issues between China & the USA.DJI is the parent company not the brand. Amflow is the brand. DJI developed the Avinox motor and system. Their electronics experience is in drones and cameras neither of which are anywhere close to the stresses and environment an emtb experiences. No bike, mtb, emtb experience in DJI or Amflow. Just access to low cost electronic components and labour and no doubt additional financial support from CCP to help disrupt another Western industry sector.
