Yesterday on the trail at Sherwood Pines my bike (Santa Cruz Vala) suddenly became sluggish. I checked all the usual things: Motor, was I dragging anything, obstruction, brakes binding and so forth. I came to the conclusion that the freehub was at fault. Pines bike shop are a Santa Cruz dealer so I went straight there.
Half an hour late I was told the following: The e13m freehub has seized and unwound the Sram Cassette. The cassette has been rubbing against the inside of the frame (fortunately, up against a metal piece that looks to have been put there for that purpose). The cassette is scrap. The wheel bearings were OK, but the hub was solid. Not e13 again I thought. So I wrote to the head of customer support in the USA, someone that had contacted me on another thread on this Forum about e13 hubs.
This was his response (spoiler alert - Not the fault of e13, but SRAM!)
I am happy about that response from e13. Not so happy that SRAM have this issue and are waiting for riders to experience the problem for themselves, rather than doing a recall or announcing a fix whatever... But maybe they have and I just am unaware of it. I will keep you informed.
Chris Costello (e13 Support)
Jun 23, 2026, 15:49 PDT
Hi Steve,
Sorry to hear about this. Ive added James at Sherwood Pines Cycles to this email.
Unfortunately the hub failure was the result of your SRAM Transmission cassette loosening under normal use, contacting the derailleur mount and creating extreme inward force on the driver body. This issue is starting to be seen more and more on all Transmission spec ebikes despite it likely being installed to correct torque specification.
The cassette loosens to the point that it contacts the derailleur mount, and then the contact with the cassette lockring end causes a rapid loosening and heavy inward force on the driver. With some hubs it will cause excessive binding and lock the wheel up. With others it will cause the driver shell to push inward
Here is a Facebook post in the SRAM Transmission FB group where many riders of different model hubs are experiencing the issue:
We are in the process of drafting a Technical Service Bulletin about it. Despite the issue not being caused by our hub and being a direct result of the cassette loosening, we are helping riders with hub parts and SRAM should be contacted about parts and labor outside the hub. Ive been in contact with SRAM's USA Customer Experience Manager and he asked that cases be directed to SRAM.
Im going to pass your ticket to Joe at our UK office and he can work with James to get you sorted as quick as possible. From our end, I would suspect we can get something out to you quickly but need to confirm with Joe. The rest of the timeline would depend on SRAM and Sherwood Cycles service availability.
You guys should hear from Joe shortly. If you need anything further from my side, please send me a message .........
Thanks,
Chris
