So a chain and cassette lasts about 2,500km = 1,500 miles?Bosch powered ebike chewing up chains and cassettes twice replaced in 5000km. Mechanic states it is because of the narrower gears and chains on the 12 speed. Thoughts please?
Welcome to e-bikes.Bosch powered ebike chewing up chains and cassettes twice replaced in 5000km. Mechanic states it is because of the narrower gears and chains on the 12 speed. Thoughts please?
What cassette, what chain?Bosch powered ebike chewing up chains and cassettes twice replaced in 5000km. Mechanic states it is because of the narrower gears and chains on the 12 speed. Thoughts please?
I asked @Eon in post #2 ...What cassette, what chain?
What conditions are you riding in and what is your bike and transmission?
This is a Bosch Performance Line CX @ 85NM of torque. I have the same motor in a similar bike but only 10 speed with a much longer chain/cassette life span. Riden mostly on rail trails at average 20 kph so mainly in higher gears - I’m easy on my bikes as I just need to enjoy the ride without torturing them. BTW 2 chains and 2 cassettes within 5000km becomes expensive cycling. Chain well maintained cleaned, lubed etc. also consider that in Australia e-bikes are governed to 25km after that you’re on your own steam on a very heavy bike. Time to go back to acoustic?Bosch powered ebike chewing up chains and cassettes twice replaced in 5000km. Mechanic states it is because of the narrower gears and chains on the 12 speed. Thoughts please?
the bosch release in the next month will include a 45kmph limit in select markets... not sure about aus.This is a Bosch Performance Line CX @ 85NM of torque. I have the same motor in a similar bike but only 10 speed with a much longer chain/cassette life span. Riden mostly on rail trails at average 20 kph so mainly in higher gears - I’m easy on my bikes as I just need to enjoy the ride without torturing them. BTW 2 chains and 2 cassettes within 5000km becomes expensive cycling. Chain well maintained cleaned, lubed etc. also consider that in Australia e-bikes are governed to 25km after that you’re on your own steam on a very heavy bike. Time to go back to acoustic?
We are still waiting your chain/cassete specs, not interested your motor.This is a Bosch Performance Line CX @ 85NM of torque. I have the same motor in a similar bike but only 10 speed with a much longer chain/cassette life span. Riden mostly on rail trails at average 20 kph so mainly in higher gears - I’m easy on my bikes as I just need to enjoy the ride without torturing them. BTW 2 chains and 2 cassettes within 5000km becomes expensive cycling. Chain well maintained cleaned, lubed etc. also consider that in Australia e-bikes are governed to 25km after that you’re on your own steam on a very heavy bike. Time to go back to acoustic?
My son has the same gearing on his eMTB and I changed everything at 800 miles.
Indeed.That is not an M6100 cassette
The very best way IMHO to measure chain wear without the need to remove the chain from the bike (new connector link) and equivalent to measuring with a rule, is this tool from Abbey Bike Tools LL Chain Wear Tool1. As long as you buy a quality chain, you will do better than economising by buying cheap chains. Not only will your chain last longer, but because it lasts longer, so will the rest of your drive train. A worn chain acts like mechanical AIDS; it spreads the wear to everything it touches.
2. Measure the length of your chain on a regular basis to keep an eye on it. Once it starts to go, it and everything else it touches can go rapidly. You can use gauges, but they are too imprecise (OK/Scrap). But I prefer to remove the chain and measure over 100 links (50"). The amount over 50" is the wear. Over that disstance a metal tape measure used properly is very accurate.
Is that^^^ any more accurate than Park Tool CC-2 Chain Checker, and if so how much more accurate? I always take more than one reading with the PT CC-2 on different parts of the chain.The very best way IMHO to measure chain wear without the need to remove the chain from the bike (new connector link) and equivalent to measuring with a rule, is this tool from Abbey Bike Tools LL Chain Wear Tool
Very expensive (for what it is) BUT easy to use and deadly accurate on ALL chains (Flattop has larger diameter rollers)
All listed photo included.
Wow lol. I’ve also said it many times, if Bosch does it you guys would lay off the restriction talk. Turns out I was rightI've stated too many times that I support Class 1 standards, in the USA anyways.
That said, if the power is the same I'd like to have a higher top speed for jumps and road transfers. It's a bummer to have no assistance in the top 2-3 gears if you have any cadence at all.
No Aus governed as in Europe 25kms assist onlythe bosch release in the next month will include a 45kmph limit in select markets... not sure about aus.
We talking bikes or building codes here?Wow lol. I’ve also said it many times, if Bosch does it you guys would lay off the restriction talk. Turns out I was right. Guess it’s not dangerous to trail access and human life if it’s bosch. You have to have over 60 posts on class 2+ rhetoric
