Fuckedbike
- Jun 22, 2026
- 2
- 0
Silver toque bolt drive side which holds the ep8 motor to the frame. Attached the missing boltI'm going to be honest — that question's a bit cryptic, so let me make sure I'm answering the right thing.
Reading it as "is the bolt possibly an M8, T40, single bleed/blue thread-lock?" — but I genuinely can't tell which bolt you mean on your Vitus E-Sommet. There are a lot of M8s on that frame, and the torque and head type vary depending on which one.
A few things I can tell you straight:
M8 + T40 is an unusual pairing. A T40 Torx is a fairly large drive — you'd normally see it on bigger structural bolts. Plenty of pivot hardware uses M8 but with a hex (commonly 5mm or 6mm) or a smaller Torx, so if yours genuinely takes a T40 it's worth noting which pivot it came from. That's not me doubting you — if T40 is what's seating in the head, that's what it is.
"1bl" I'm not sure on. If that's shorthand for blue thread-locker (medium-strength, like Loctite 243), that's the right stuff for most frame pivot bolts — removable but won't rattle loose. If it means something else (a part number suffix, a bleed reference), tell me and I'll re-aim.
On torque — I don't have the verified per-bolt torque table for the E-Sommet frame to hand, so I'm not going to invent a figure. For reference, @TCFlowClyde ran a custom titanium main pivot M8 at 10–12 Nm, but that's a different frame and Ti bolts torque differently to steel. Don't apply that to yours blind.
Worth knowing: @Ndanger makes the point that some brands deviate from the "standard" torque with custom inserts or washers, so the only number I'd trust for a structural pivot bolt is the one in the Vitus service manual for your frame.
If you can tell me:
• Which bolt — main pivot, shock mount, lower link, motor mount?
• Whether you're after the torque spec, a replacement, or confirming the thread-lock?
…I'll give you the exact answer rather than guessing across a frame full of fasteners.
What's the bolt and what are you trying to do with it?
@Fuckedbike - welcome to the forum, good that you've got a photo of the missing bolt - that's exactly the right way to approach this.Silver toque bolt drive side which holds the ep8 motor to the frame. Attached the missing bolt 187230
