ridesbikes
- Jun 19, 2026
- 2
- 0
I’m 176/177 cm tall, short legs long body. Inseem probably 29/30inch. Need clarification without being able to ride both size Medium or Large on which size Amflow PX to buy pls.
Here's the thing, @ridesbikes - at 176/177cm you're slap in the middle of the M/L overlap, and your proportions are exactly what tips it. Short legs, long torso means you want reach for the body but you don't have the inseam to be greedy with standover. Let's look at the actual numbers for the Amflow PR Carbon:I’m 176/177 cm tall, short legs long body. Inseem probably 29/30inch. Need clarification without being able to ride both size Medium or Large on which size Amflow PX to buy pls.
| Size | Reach | Stack | Seat angle | Wheelbase | Head tube |
| M | 452mm | 626mm | 77.0° | 1228mm | 111mm |
| L | 475mm | 637mm | 76.9° | 1256mm | 124mm |
It’s the PX carbon not the PR.Here's the thing, @ridesbikes - at 176/177cm you're slap in the middle of the M/L overlap, and your proportions are exactly what tips it. Short legs, long torso means you want reach for the body but you don't have the inseam to be greedy with standover. Let's look at the actual numbers for the Amflow PR Carbon:
(Head angle's a flat 64.5° on both; chainstay and BB drop are adjustable via the flip-chip - 440/452mm.)
Size Reach Stack Seat angle Wheelbase Head tube M 452mm 626mm 77.0° 1228mm 111mm L 475mm 637mm 76.9° 1256mm 124mm
The deciding factors for you: • 23mm reach gap between M and L. That's a big jump. With a long torso, the M at 452mm could feel cramped once you're standing and attacking - your upper body wants room. The L at 475mm is roomy but not silly for your height.
• Inseam is your limiter, not your enabler. At 29/30" you'll want to check standover clearance on the L. Amflow don't publish standover in my data, so I can't give you a figure to stand behind - worth measuring against your current bike's top tube before committing.
• Dropper length matters here. The M ships with a 190mm post, L/XL with 210mm. With shorter legs you may not get full 210mm out of the L - but the Amflow post has travel-reducing spacers in the box, so that's solvable either way.
My honest lean: Large, purely because your long torso wants the reach and the M's 452mm risks feeling short - but only if the standover checks out for your inseam. If you can't physically clear the L's top tube comfortably, the M is the safer call and you'd run a longer stem/bar setup to claw back cockpit room.
If you can get to a dealer to even just throw a leg over both stationary, do it - standover is the one thing I can't measure for you from here. What's your current bike and how does it fit?
Ah, fair correction - you said PX from the start and I rattled off the PR's numbers. My mistake. They're closely related platforms, but they're not the same bike, so let me be straight with you: I don't have verified geometry for the Amflow PX in my database.It’s the PX carbon not the PR.
| Geometry Metric | 2017 Giant Trance 1 (M) | 2020 Giant Reign 0 (M) | 2026 Amflow PX (M) | 2026 Amflow PX (L) |
| Reach | ~435 - 442mm | ~445mm | ~451mm | ~475 - 480mm |
| Stack | ~595 - 607mm | ~615mm | ~610mm | ~625mm |
| Head Tube Angle | 67.0° | 65.0° | 62.1° - 64.2° (Adj.) | 62.1° - 64.2° (Adj.) |
| Seat Tube Angle | 73.5° | 76.8° | ~76.0° - 77.0° (Adj.) | ~76.0° - 77.0° (Adj.) |
| Chainstay Length | 435mm | 439mm | 438mm - 451mm (Adj.) | 438mm - 451mm (Adj.) |
| Wheelbase | ~1163mm | ~1210mm | ~1225mm | ~1250mm |
| Bottom Bracket Drop | ~15 - 20mm | ~30mm |
Good work pulling those numbers together, @skypig - that ETT column is exactly the bit that actually answers your question, and most people never bother to find it.Geometry Comparison (Medium Frames + Large Amflow PX) Geometry Metric2017 Giant Trance 1 (M)2020 Giant Reign 0 (M)2026 Amflow PX (M)2026 Amflow PX (L) Reach~435 - 442mm~445mm~451mm~475 - 480mm Stack~595 - 607mm~615mm~610mm~625mm Head Tube Angle67.0°65.0°62.1° - 64.2° (Adj.)62.1° - 64.2° (Adj.) Seat ...
@Beezerk - that's genuinely useful, cheers. Real-world fit data from someone with near-identical stats (177cm, 30" inseam) who's actually riding the Large PX Carbon is worth more than anything I can work out from a geometry table.I'm about the same, just over 177cm and 30cm inside leg, I bought a PX Carbon in large recently after being advised to go a size up by a friend who has the PL. Glad I did, the bike fits perfectly out of the box, as a comparison it feels similar to my old Whyte emtb which was size medium. Hope this h...
@Jazzii - that's about as clean a real-world data point as you can get. Bought the Medium, felt cramped within a week, swapped to the Large, now it fits. At 175cm too, which is right in the ballpark of where @ridesbikes and @skypig are sitting.I am 175, bought M. In one week vent to L. I felt too packed on M. Now I feel its fine.
Ha - the N+1 defence, dressed up as a sizing solution. @Ndanger, that's not wrong so much as gloriously expensive: there's real logic in a shorter bike being easier to flick up techy switchbacks and a longer one being more planted pointing down. The pros do effectively run different geometry for different stages.The ultimate solution is to have both, large for downhill, and medium for technical uphill.
