ridesbikes
- Jun 19, 2026
- 2
- 0
I’m 176/177 cm tall, short legs long body. Inseem probably 29/30inch. Need clarification without being able to ride both size Medium or Large on which size Amflow PX to buy pls.
Here's the thing, @ridesbikes - at 176/177cm you're slap in the middle of the M/L overlap, and your proportions are exactly what tips it. Short legs, long torso means you want reach for the body but you don't have the inseam to be greedy with standover. Let's look at the actual numbers for the Amflow PR Carbon:I’m 176/177 cm tall, short legs long body. Inseem probably 29/30inch. Need clarification without being able to ride both size Medium or Large on which size Amflow PX to buy pls.
| Size | Reach | Stack | Seat angle | Wheelbase | Head tube |
| M | 452mm | 626mm | 77.0° | 1228mm | 111mm |
| L | 475mm | 637mm | 76.9° | 1256mm | 124mm |
It’s the PX carbon not the PR.Here's the thing, @ridesbikes - at 176/177cm you're slap in the middle of the M/L overlap, and your proportions are exactly what tips it. Short legs, long torso means you want reach for the body but you don't have the inseam to be greedy with standover. Let's look at the actual numbers for the Amflow PR Carbon:
(Head angle's a flat 64.5° on both; chainstay and BB drop are adjustable via the flip-chip - 440/452mm.)
Size Reach Stack Seat angle Wheelbase Head tube M 452mm 626mm 77.0° 1228mm 111mm L 475mm 637mm 76.9° 1256mm 124mm
The deciding factors for you: • 23mm reach gap between M and L. That's a big jump. With a long torso, the M at 452mm could feel cramped once you're standing and attacking - your upper body wants room. The L at 475mm is roomy but not silly for your height.
• Inseam is your limiter, not your enabler. At 29/30" you'll want to check standover clearance on the L. Amflow don't publish standover in my data, so I can't give you a figure to stand behind - worth measuring against your current bike's top tube before committing.
• Dropper length matters here. The M ships with a 190mm post, L/XL with 210mm. With shorter legs you may not get full 210mm out of the L - but the Amflow post has travel-reducing spacers in the box, so that's solvable either way.
My honest lean: Large, purely because your long torso wants the reach and the M's 452mm risks feeling short - but only if the standover checks out for your inseam. If you can't physically clear the L's top tube comfortably, the M is the safer call and you'd run a longer stem/bar setup to claw back cockpit room.
If you can get to a dealer to even just throw a leg over both stationary, do it - standover is the one thing I can't measure for you from here. What's your current bike and how does it fit?
Ah, fair correction - you said PX from the start and I rattled off the PR's numbers. My mistake. They're closely related platforms, but they're not the same bike, so let me be straight with you: I don't have verified geometry for the Amflow PX in my database.It’s the PX carbon not the PR.
The AI's logic isn't daft here, @skypig - your Reign-feels-short-with-the-seat-slammed-back observation is the whole game. That's a rider whose torso wants more reach than a modern steep seat tube gives you once you're seated and pedalling. So I get why it pushed you toward the Large.I’m only 174cm tall. Have a 2017 Trance Medium that seems to fit like a glove. My 2020 Reign also a medium feels short, in the reach department - I run the seat all the way back. Obviously due to the much steeper (more modern) seat tube angle. Looking at an Amflow PX. Assumed I’d get another Medium ...
| Geometry Metric | 2017 Giant Trance 1 (M) | 2020 Giant Reign 0 (M) | 2026 Amflow PX (M) | 2026 Amflow PX (L) |
| Reach | ~435 - 442mm | ~445mm | ~451mm | ~475 - 480mm |
| Stack | ~595 - 607mm | ~615mm | ~610mm | ~625mm |
| Head Tube Angle | 67.0° | 65.0° | 62.1° - 64.2° (Adj.) | 62.1° - 64.2° (Adj.) |
| Seat Tube Angle | 73.5° | 76.8° | ~76.0° - 77.0° (Adj.) | ~76.0° - 77.0° (Adj.) |
| Chainstay Length | 435mm | 439mm | 438mm - 451mm (Adj.) | 438mm - 451mm (Adj.) |
| Wheelbase | ~1163mm | ~1210mm | ~1225mm | ~1250mm |
| Bottom Bracket Drop | ~15 - 20mm | ~30mm |
Good work pulling those numbers together, @skypig - that ETT column is exactly the bit that actually answers your question, and most people never bother to find it.Geometry Comparison (Medium Frames + Large Amflow PX) Geometry Metric2017 Giant Trance 1 (M)2020 Giant Reign 0 (M)2026 Amflow PX (M)2026 Amflow PX (L) Reach~435 - 442mm~445mm~451mm~475 - 480mm Stack~595 - 607mm~615mm~610mm~625mm Head Tube Angle67.0°65.0°62.1° - 64.2° (Adj.)62.1° - 64.2° (Adj.) Seat ...
