2027 Orbea Wild LT Released - Avinox Powered
So, when are we going to read some rider reviews, weights, etc.?
Anyone in this thread getting one this month?
Stoked to hear about the new Wild from real owners!
I've ordered a Karve EVO RSX and delivery is 16th July, so i would be really interested to hear what the Orbea is like as it was a bike I was considering but I wasn't sure when it would be released or delivery dates
This is what scares me a little buying a bike before hopping on it. The Large is very close in numbers to my current S4 enduro which I love so I'm hopeful the Wild will be a similar fit. But at 5 ft 10in, I'm sort of between sizes which is always fun 🤣
100% same here. 5 10, love my s4 enduro. will go L on the wild. 😊
The only Orbea dealer near me told me he wouldn’t have any stock until September or October. It’s a really small shop so I’m guessing he’s way down on the list to get bikes though. The bigger online shops down in England all say “dates to be confirmed” so no idea when they’ll be getting any.
The MX size Large wheelbase spec is loooong at 1288mm. My S4 Levo 4 in long (444mm) chainstay setting has a 1233mm wheelbase! Plus 55mm is a bit concerning for where I ride. The 73,6º seat tube is a a lot more slack than anything I've been considering too. Might need to demo a Wild before I'm ready to order.
This video from Hawes (even just the first 20 seconds) provides context for my concern about the long wheelbase.
You sir could benefit from a well practiced nose wheelie turn. That will solve ya problems.
Well, Orbea havent just chucked an avinox motor and battery in a bike like pretty much every other company. They have developed there own mapping, electronics and integration. So Kudos to them for taking development to the next level.
For me i'd ditch the Electric shifting and electric shock. I'm not interested in that in the slightest. wouldn't mind the integrated e dropper.
But that hard wired remove cable through the bar is stupid, stupid. They need to make that remote wireless.
Its good to see them ditching the headset cable routing too.
The bike is sexy as fuck. Definitely one to put on the list to consider for my next E.
I realize it's tempting to comment on my (lack of) skills and technique, but frankly it's missing the point. A longer bike will simply make it more difficult and demanding to navigate tight situations than a shorter one would. This reality only becomes more pronounced as rider skill level goes down. I already see the difference it made going to my Levo's long chainstay setting; and that's only +9mm. I do like this long setting and run it on my Levo, but the thought of riding a bike that's another 55mm(!) longer seems like it would be like driving a semi. I want to test one before I place an order. Might not even have to if Orbea locked out Class 3 mode though. We'll see.
Your skills and technique are fine man! I think more people should film themselves pov and see how humbling it is. What you thought looked blazing fast and huge drop looks like nothing on camera lol. Really gives you perspective when you watch the pros pov.
Sure shorter bikes are better for tight. But worse for fast. This bike is pretty standard geo and wb for a 170 big hitting enduro bike. All other bikes in this category will have similar wb's. So if you want a 170/180 stormer you will have to give up wb from the shorter travel am/trail bikes. You can have stable, long, low and slack with gobs of travel with a short wheelbase unless you purposefully undersize the bike and ride cramped.
The answer in super tight is to build your nose wheelie capability. Then all of a sudden the tight switch back problems go away. Its a good skill to have regardless of the bikes wheel base.
Unless the specs I'm seeing are incorrect; I don't agree that the Wild's wheelbase is average for 170 travel bikes. It's on the long end of the spectrum, even within the category. I'm not even saying that is a bad thing for everyone; I'm just saying it seems like a bad thing for how and where I ride.
The nose wheelie/pivot isn't near a full solution. It could be an option of tight switchbacks, but not in tight situations where you're snaking between things at a quicker pace. Overall, it feels like the wrong approach to have to adapt a completely different (and probably slower) technique in tight situations because the bike I'm riding is so biased towards high-speed stability.
I'm an audio guy by trade so to me it's like someone claiming a pair of Focal Utopia tower speakers are a good choice for a frat party. As good as the Focal's are, they going to far less than ideal for a frat party. The smarter move is to pick a more appropriate tool for the job instead of finding a way to make the less-ideal solution work.
First ride was very promising, felt very comfortable right away. I had the 2023 alloy model before, which i also really liked... geo is pretty similar. too early for any verdicts on suspension curve, stiffness, etc.
I’d estimate the Karve frame around 3kg-3.5kg
Wild is 2.6kg
So around 400g to 900g heavier
My Wild is 23.7KG
Good info. Yours has all the things right? XL frame, 800wh, F38, X2 Neo shock, AXS, electronic dropper, full 29er?
Does that include pedals? What are the tires?
Thx.
Thx.
Yes fully loaded.
Alloy wheels. DH Maxxis 29” front and rear. Live valve. 240mm dropper. 800 battery.
No pedals when I weighed it.
@kEARNEY79 I think the biggest thing on these bikes will be the geo and suspension.
Karve= better front to rear balance, size specific chain stays, 4-bar linkage
Wild= slightly lighter, concentric axle pivot linkage driven shock, fixed chainstay length
What size you thinking?
That's an impressive weight for that build and battery.
Not bad.
Really frame weights are the biggest differentiator now.
Orbea at 2.6kg is very light. The Unno is also 2.6kg. Pretty much the lightest frames you can get for enduro ebikes.
Best way to compare these bikes builds really is frame weights. Everything else is parts strapped to them!
    673K
