Here my impression after 3 weeks of ownership, 12 tours, 15789m elevation, 283km.
Size L, alloy wheels, gravity tires, Fox DHX2 Coil, Fox 38 170 2027, Maven Ultimate, 24.8kg.
My previous bike Giant Reign E+, L, Zeb Ultimate, Fox DHX Coil.
My riding skills are Average Joe level. Terrain: 90% single trail, ½ in forest and ½ in alpine. No bike park, no MTB dedicated trails. I don’t do big jumps or big drops.
I like technical steep ascents and descents, like to explore, and don’t mind pushing the bike if needed.
The good:
- Frame option that you can build your own, super fan of it.
- Downhill is just amazing, super stable and a lot of grip, I’m faster everywhere and more confident in the steep technical sections. The back suspension system works very well.
- Easier to do nose press switch backs. I’m not sure why but it is quite easier than my Giant although geo is quite similar.
- Lower seatpost, I can run 200mm AXS instead of my previous 175mm.
- The bike, although full enduro, is quite nimble and easy to move around.
- Climbing is insane, ¾ of the sections I was pushing before I now can fully ride. It took me a week to get use to the power, gears to use and overrun. Roots, rock gardens and step alpine broken paths are much more accessible with this bike. I use it a lot in Turbo and I just laugh at people that say you cannot use so much power, as an average joe as I’m can use it, people with much more skill will climb even more challenging sections. This thing can deliver power so well that it almost never spins even at 130nm, something that I was doing a lot on my old at 85nm
- 12a charger is practical for long tours, assuming you have electricity, as you can charge almost 500wh in 1h. See below for negative.
- Customization and Display are great, I have my own modes: for example I have a Turbo with the default overrun and an OverT that is Turbo with max overrun. I have my 4 pages of display that show me the key info that I need.
- 65w USB-C, is a good feature as I can charge my phone or I can plug in a 120g, 3000 lumen front light that I keep in the backpack if dark catches me.
- Push to walk works well and is nice that it holds position.
- Smart shifting is handy and the gear on the display is practical
The bad:
- No range extender and not sure there will be ever one that fits. I do also long alpine tours with no electricity. I now need to plan detours (last one was 5km detour) just to go and recharge it and I’m not a fan. Also, not everybody let you recharge it.
- Starting from stand still on steep terrain is more difficult than with my old Yamaha motor. I have set quick start on and max start assistance. Sometimes I use push to walk to start. But the Yamaha was noticeable easier, then once you start moving then DJI is just on another league.
- Comes with 4a charger not with 12a, is a bit of cheap for a premium bike. Ideally it should have only one charger that is switchable 4a and 12a. The 4a is useful when recharging at some alpine huts as they have old inverters that do not like 500w, let alone multiple 500w.
- 203mm back rotor mount. This is wired as their full bikes ship with Mavens that does not have 203 rotors. Apparently new models come with 200mm
- Charging port cover is a joke, very cheap and you need to pay attention that you seal it well.
- Cable routing exposed at the cranks are prone to be broken.
- 1st day mine was also squeaking a lot, after regreasing ad retightening is now fully silent.
- Velduro communication is not great, not sure it is Velduro or our importer, anyway thanks that there is @Velduro UK that gives us a lot of useful information!
- Not much space for large back tires especially if you run full 29’. I run 2.5 on mullet so is not an issue for me but good to know.
To be seen:
- Reliability
- Velduro support
- Idler sturdiness
- Transmission wear, I personally don’t care too much as is so much more fun to climb that I’m ready to pay the price for changing cassette, chain, chainring more often.
Bottomline is a great bike with a great motor that makes an average joe a better rider.
nice review! What did you specifically regrease to quiten the creaks?
Anyone else has a squeak/klonk noise coming from the motor area when starting to pedal/weight shifting?
The noise I had on day 1, it started small but then developed in to this 🎧:
The fix was completely removing this pivot, clean it and grease it, since then my bike is totally silent (other than the normal motor noise when going up hill)
In defence of them, that pivot not being greased/clean etc is pretty common on a LOT of bikes. It shouldn't be, it should be RIGHT, but that's the world in which we live. Even if it's right from the factory, it's the most abuse pivot point on bikes, so will need attention soon enough.
Thanks for the tip. I already have set to on after the first ride and also the start assistance to max.
Just to be clear is not impossible to start from stand still in very steep terrain, it just requires more effort and more technique than with my old motor. Basically I need to spin it faster and put more pressure the pedal that requires more balance.
In the trails around here sometime there are tight switchback that I can't do uphill so I need to dismount, restarting is where I notice the difference. Here I'm going down (I do nose press switch) but when I come up-hill my technique is not good enough to do the switchback so I need to dismount to switch the bike. Restarting in these cases is where I notice the difference. It is the only thing that I find it worst that my pervious bike. Not a big issue but is something the DJI could further improve:
View attachment 185885View attachment 185886
The issue is the motor/Rider interface.
You have to have instant torque, set by the pedals - Something (Alex ebike tester, refer over and over when testing +cadence than torque motors)
Bosch is one of those motors, and with eMTB+, the overun can sort you out.
Alex anti Avinox BS.
I found the issue, I had the freehub pre-engagement set to on, this makes the initial pedal stroke heavier thus requiring me to put more pressure and consequently requiring more balance.
With this setting off it is as easy to start as with my old bike/motor.
I tested with on and off on the same steep restart and with off is giving me the same feeling as my previous bike so I'm happy camper. I'm sure is more feeling + technique but to me it makes a noticeable difference.
cc @Taxi Man
I've checked all the pivot screws and all were greased superb.
I think that it was the lower bolt of the battery. I was surprised how short the lower screw is 👀
Finally finished.
Took way longer than planned but results is unique and satisfying.
Yes, the yellow rims are a bit hideous but it was too big of a vintage call to miss for someone like me who still has a pair of those 20 YO old rims with aluminum spokes in the garage
Does anyone have an assembly diagram for the rear triangle? I get the feeling something’s wrong with mine or that something’s missing. The link is really stiff to move and the washers are corroded.
I couldn’t find anything on Velduro – really poor!
First weekend on my Rogue. Finished building it on Friday and hit two local spots over the weekend. Very different bike to my old full fat Kenevo, in a very good way. I was worried that the shorter reach and higher stack wouldn’t gel with me. But after two great rides I was very wrong! Bike is so stable and fast, even when it’s getting rowdy is so predictable when it gets to the edge of traction. I love it! Several more rides planned this week. A few tweaks to the suspension set up planned
Anyone else left the rear end setting on 29 with a 650b rear wheel for MOAR slacks? Certainly on my local steep and rough trails it feels awesome
Local shop built mine up with the chip set to 29 & i left it there,was planning on flipping it to 27.5 at some point just to see what the difference is,but I know im quite slack & probably won't bother.
    673K
